ca alternator.......35
ca pas pump........30
ca crank sprocket.....20
flywheel bolts......25
200sx stainless coilpack cover 10
ca cast manifold....15
ca throttle body cleaned ..... 30
hks fmic has dings in it the pipes are green diy style with red hoses beware this is tatty but holds air fine
paint could be removed alright as a temp till you get a shiny one theres a pic you can just make out under my user name say 70ono
s14 rear seatbelts and buckles...50
S14 cast manifold.....15
S14 auto rad can be used in manual ...25
fog lights for s14 with brackets attached .....20
S14 recirc bov standard.......10
S14 auto tps.......5
Sr20det coil pack loom .....20
s14 rear discs .......10
s14 handbreak cables......30
s14 rear brake pipes and fittings......30
I'm also breaking a ca engine as the block is knakered and not worth following up so if you after bits to build a ca heres the list
ca bare head includes the valves in good condition working
ca lifters x 16
cams exhaust and inlet
cas
rocker covers and cam covers in green
sump
wood ruff key
crank sprocket
fuel rail
injectors
and all the little bits
i have all the nuts and bolts off the engine bag and labelled if you missing any
Superchips Bluefin Ford Focus 2.5 RS MK2 STAGE 2 BF06-RS09-T comes in box includes handset , disc , usb lead , and manual
everything's there ive heard this can be used to read codes on other cars but not sure how true this is
asking 180 posted to your door
couple sets off m3 style mirrors one set with side repeators 10 each
rover rear trailing arm bushs new ...offers
universal net for storage in a car 10
t25 inlet housing 5
ca lifters x 16
cas
sump
wood ruff key
crank sprocket
fuel rail
injectors
t25 inlet housing 5
