Eaton M62 supercharger, I've removed the magnetic clutch to see how it works and if it can be locked off or a normal snout fitted, all the main parts are there to re-assemble the clutch if wanted, can't remember about the spacer washers for the magnetic friction plate? £250
Rover V8 cylinder heads with rockers, they've been re-faced/skimmed before I got them, 14 bolt Range Rover/SD1 type, £40
Rover V8 ARP cylinder head studs, fitted to an engine but never run. Might have the box somewhere? £120
Rover V8 P5/P6 rocker covers, painted red now covered in white overspray, £10
Rover V8 serpentine distributorless timing cover, been using it for mocking up on a spare engine block, £40
