For sale is my ABF conversion specifically for non GTi spec cars.
Contains
1998 ABF unknown mileage but I would guess due to cambelt change just under 200k miles however when I inspected it it ran sweet as a nut.
Engine is bolted up to a standard mk2 gti box (still has flywheel, and clutch setup) this is the cable box (020?)
100mm driveshafts, I was told one is knackered but haven't looked myself tbh
Complete front gti subframe with all suspension etc right down to the brakes (big vented buggers)
Gti rear beam which has been shot blasted, painted and new OEM bushes fitted
Gti fuel tank and pumps
The engine wiring loom is uncut and even has the loom for CE2 lighting still attached and the ECU has been deimmobilised so this literally is a plug and play package for those of you running a CE2 car
Rear discs are practically new they are just standard gti solid discs
I was told the throttle body has been ported too but not 100% on this one
£600 for the lot, will not split any items.
Collection only from Worcester
Pm me if interested
Cheers
Luke
Contains
Pm me if interested
Cheers
Luke
