pioneer speaker pods, a little tatty, but work well. 20 watts max, 4 ohm impedance
£30 inc post or £25 collected
Alpine graphic EQ with in-built 25 watt per channel amplifier in good working order.
2 channel input, gives 4 channel output @4 x12.5 watts (can also be used as a 2 channel in, 2 channels out, you will just get 2x25watts out)
Made in Japan, quality car audio, rather than cheapo made in china stuff you can buy new
Metal case has some surface rust, but nothing detrimental to it functioning. The front panel (the bit you actually see when installed is in good order)
Wiring loom has been cut down a bit. There is no mounting bracket included.
£35 posted, £30 collected
Blaupunkt cd player from early 90s
These are great little radios, I run a fully working one in my polo g40 as it is such a good likeness for the original pull out cassette player.
This unit is in tidy condition, but needs decoding via a chip reader (most car audio specialists can do this for around £25).
It also needs a replacement cage.
The backlighting will probably need replacing too (an easy DIY job which if I had the spare time I would have done myself)
The good thing about this model is that it uses iso plugs and has a 3rd iso from which you can obtain a line out convertor lead so you can hook up external amplifiers to it (great if you want to run a sub or even just a more powerful amplifier).
£30 posted £25 collected
audiobank class a/b amplifier. great for using with old car radios as it take speaker level inputs. fairly diddy, but with give similar power output to modern headunits.
£12 posted or £5 collected.
All items can be collected from either oxford airport or hook norton, oxon
