Prices with part description. if you're interested please give me a call/text on 07860 274834. PM if you perfer but can be a bit slow to check that so won't guarantee you first place in line should anything be popular!
Crossflow Engine
Following change of direction engine wise, I have a nice spec Crossflow for sale – basically a stage 3. Last running on Sunday, and runs very well with good oil pressure. Oil changed more than it needed and having popped the sump off for photos it all looks very clean. Was rebuilt about 3-4000 miles ago, so it’s still pretty fresh. It does need a sump gasket thought, due to me popping it off for photos.
Specs:
- 711M Block, not had the head off but told a 1660cc by the guy I bought from
- Very well ported and polished head on inlet and exhaust sides, with larger valves
- Steel rocker posts and upgraded adjusters
- Double valve springs
- Duplex timing chain with Vernier gear
- Piper BP270 Camshaft
- Lightened flywheel
- Balanced crank/pulley/flywheel set
- Weight matched rods/pistons
- High pressure oil pump
- Type 9 fitment clutch (less than 2000miles old)
Going to say £650 for this, as I know it’s ready to bolt in (baring the sump gasket) and know it’d cost a lot more to build to the same spec from new parts. I am open to near offers though, collection only due to weight – happy to help with loading.
Having a clear up of all my Crossflow related parts as well, again open to offers. Will post, just ask for a price:
Crossflow fit Bosch electronic ECU, with lead. Clean part with no nasty play. Plumbs in very easily and works great, nice reliability upgrade from a standard dizzy. Not sure how much these are worth - £50?
Peco twin 40/45 inlet manifold for sale, this is ported to match a ported head and then polished. Very nice part, fits Escort engine bay with stubby trumpets. Say £50?
ITG sausage filter back plate, crossflow fitment (matches the manifold above). Fixing clips missing, so say £10?
Formula Ford equal length exhaust manifold. Nice part this, picked it up to use as a basis of an exhaust that never happened. Goodness knows what it’s worth - £50?
4 into 1 Crossflow exhaust manifold. Sadly this one split around the collector. Has been welded back up to a decent standard, but cheap because of that - £10?
32DGAV Carb, think this is the Mk1 Mexico type carb on Crossflow manifold. Was jetted for an old 1600 Stage 1 I had, and the cold start mech actually works correctly as well! £40?
K&N for twin chock weber downdraft (DGAV etc.) £15?
Crossflow Engine
Specs:
