I am looking for a pair of drive shafts to use with a sierra Diff and use a mondeo mk2 hub , bearings and outer Cv case for its abs sensor pick up mounted into a purpose made bearing carrier(uses all the items I already have from the donor car and I know it will take the power, new were parts ect) Its a concept At the moment but looking for some help with suggestions of suitable shafts.
a sierra uses drive shaft lengths of 796mm and 767mm fully compressed
I am looking for anything around the 785-800mm mark and between 26mm to 28mm in diameter. a pair the same as I am fabricating the rear sub frame myself. I will work out what Cv joints to use when I finalize the drive shafts, have done a bit of research on lengths of other cars but there are some knowledgeable people on this forum who I hope will post a catalog I have yet to find.
Dan
Dan
