firestone tank I'm now not using. approx 6.5" diameter by 19" -ish long, so a 3gallon model. 2 port, one on each end(in/out), 1/4"npt. black painted finish but a bit scratched up. £50.
various airline fittings, all solid brass, made by alkon, top quality. used but excellent condition.
7x 1/4"NPT male to 1/4 line straight
4x 1/4"NPT male to 1/4 line 90deg swivel
4x 1/8"NPT male to 1/8" line (for gauges)
£15 the lot (theres more than shown in the pic, still got to remove a few from things).
quite a lot of brand new still in packet connectors, black plastic with metal collets except the bulkhead fittings which are brass. all to accept 6mm line, i ended up going 8mm in the end so all brand new sealed in packets. easily enough to do a full car.
6x brass bulkhead inline connectors with fittings, fit a 14mm hole.
6x straight connectors
4x 90 deg elbows
6x 1/4"NPT banjo male swivel connectors
£20 the lot.
ive also had a batch of bag endplates lazer-cut.
they are 5mm thick(wont bend like some of the cheaper ones), 5.5" diameter.
will accept all bags i know of, i designed them specifically for firestone (both types) and slam specialities bags, the port clearance is big enough for 1/2" fittings as on SS bags, unlike a lot of endplates.
fitted on large-post SS bags-
and both types of firestones-
£60 for a set of 8 plates (4 top, 4 bottom).
4x 90 deg elbows
£20 the lot.
