pics up in a bit....
one set of front locking/adjuster rings for FK G1 coilovers. afaik they will fit all FK coilies. good used condition, a few pipe wrench marks but nothing detrimental to function, all threads good etc. as you probably know these appear to be made of a very soft grade of camembert, that crumbles at the first sign of road salt. luckily mine blew the inserts so theyve been well lubricated...... £45.
and from my other set, one good front shock insert. fits a wide range of stuff, but its main application is mk2/mk3 golf, b3/b4 passat, 6n polo, lupo front. part numbers up shortly so you can compare. £40.
ive also got some helper springs and one good front V spring....
