v8jim
Nov 18, 2014 20:43:49 GMT
I did have a build thread years ago but all the photos are gone and so has most of what I'd done. I've recently resurrected the build after 4 or 5 years of it doing a good impression of a shelving unit at the back of my garage I'm on a mission now to get it on the road next year (I'd love to make it to Pendine as a spectator) but it's a huge job so don't hold me to it Anyway I'm going to start with a few photos of it as a stocker and add a few more each day till its up to date This is when I collected it after buying blind on eBay,it was a surprise to find it compleatly rust free I spent the time and a few quid to get it running and driving before selling most of the running gear to restorers. And then the fun stuff began.......
Last Edit: Jul 3, 2020 19:40:14 GMT by v8jim
Max sig pic size: 80px
vulgalour
Club RR Member Number: 146
1929 model A 300tdi vulgalour
@vulgalour
Club Retro Rides Member 146
Nov 18, 2014 20:55:55 GMT
*re-bookmarked* I think I remember this from the first thread, and it was awesome then.
v8jim
Nov 18, 2014 20:59:50 GMT
Thanks and wait till you see it now I'm building it to be my daily once finished hence diesel power
It's taken me many years and cars to figure out I prefer pre war design cars so I'll probably be selling my HB Viva next year
Last Edit: Nov 18, 2014 21:01:26 GMT by v8jim
Nov 18, 2014 21:02:39 GMT
This is gonna be such a cool and very usable truck with a 300Tdi in it. Plus, there's plenty of tuning potential with the 300 as well. 25bhp extra with stock parts with a small wastegate and pump adjustment. I dunno what this weighs in comparison to a Discovery which is a tad over 2 ton. My old 300 Tdi with pump and wastegate adjusted went like a train. I would think this will go just as well, at a guess.
1964 Saab 96 two Stroke 1971 Hillman Avenger 1500 GL (Tuned 1600 fitted) 1976 Saab 99 2dr EMS (Project of very slow progress) 1978 Saab 99 2dr EMS (Awaiting reshell) 1981 Saab 99 2dr Turbo (Awaiting reshell)
Nov 18, 2014 21:04:44 GMT
P.s, I'll have to try and make it if you're there next year and have a look at it in the flesh, especially as Pendine is only about 35 mins away.
v8jim
Nov 18, 2014 21:16:26 GMT
madwelshman - have you got any info on tuning 300tdi engines? I can't find much apart from pump and wastegate adjustment,that's as far as most people seem to go. Not that I want to do a lot to it,I'd rather it be reliable and useable
Nov 18, 2014 21:33:16 GMT
No rust!? They just don't make them like that anymore!
sowen
Club RR Member Number: 24
1929 model A 300tdi sowen
@sowen
Club Retro Rides Member 24
Nov 18, 2014 21:44:09 GMT
madwelshman - have you got any info on tuning 300tdi engines? I can't find much apart from pump and wastegate adjustment,that's as far as most people seem to go. Not that I want to do a lot to it,I'd rather it be reliable and useable I remember the first thread, still looks cool My brother has fitted an Eaton M45 supercharger in addition to the stock turbo on a 200tdi, with plans on fitting a larger truck turbo at some point. He's on his third clutchplate now, it seems to shake the centre drive plate until the springs fall out, but really pulls well
Nov 18, 2014 21:48:11 GMT
madwelshman - have you got any info on tuning 300tdi engines? I can't find much apart from pump and wastegate adjustment,that's as far as most people seem to go. Not that I want to do a lot to it,I'd rather it be reliable and useable I'll have a look and see what I've got. They do respond quite well to improved breathing, a bit of head work, smoothing things out a bit. The intercooler is 'ok', but a bigger one is advised if you're gonna crank the boost up a bit. Lightening and balancing the bottom end makes them much smoother as well, just don't take too much off the flywheel. Personally, when I can (eventually) afford a Landy 110, I intend fitting a VNT turbo to it. The pump is capable of supplying plenty of fuel, especially with slight modification. But what I'm really after is the turbo spooling up a few hundred rpm lower, because it will be used to tow my 4x4 trialer and it'll make a big difference. Will
Nov 18, 2014 21:57:43 GMT
madwelshman - have you got any info on tuning 300tdi engines? I can't find much apart from pump and wastegate adjustment,that's as far as most people seem to go. Not that I want to do a lot to it,I'd rather it be reliable and useable I remember the first thread, still looks cool My brother has fitted an Eaton M45 supercharger in addition to the stock turbo on a 200tdi, with plans on fitting a larger truck turbo at some point. He's on his third clutchplate now, it seems to shake the centre drive plate until the springs fall out, but really pulls well The 200 Tdi has a smaller Turbo than the 300 has. It is noticeable on the road, especially if they've been opened up. The 200 will run out of steam sooner than the 300 when the turbo cannot produce enough boost higher up the revs. A 200 does spool up slightly quicker than the 300 though and is great for towing.
Kieran
Nov 18, 2014 22:09:17 GMT
Get a boost pin. Better ramp profile for the governor.
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
Nov 18, 2014 22:28:45 GMT
Get a boost pin. Better ramp profile for the governor. He's right :-)
v8jim
Nov 18, 2014 22:39:20 GMT
Nov 18, 2014 22:45:37 GMT
Such a cool looking truck!!
I remember this too, so bookmarked and look forward to updates.
gavs1
Bookmarked this gunna a mad thread
Nov 19, 2014 10:27:57 GMT
That will be a great daily. I live in Lanarkshire and about 18months ago, a few times, I noticed a young woman in the local Asda car park in a 1929 A 3 door saloon. It was straight, tidyish not overly ratty and no showpiece it was her daily driver!
Dez
Club RR Member Number: 34
1929 model A 300tdi Dez
@dez
Club Retro Rides Member 34
Nov 19, 2014 11:18:21 GMT
Model AA, surely?
Or are you just keeping it simple for the non-buffers?! ;-)
Nov 19, 2014 16:17:46 GMT
reminds me of the waltons the cantilever rear suspension is interesting, guess it gave it more travel?
Last Edit: Nov 19, 2014 16:19:40 GMT by darrenh
v8jim
Nov 19, 2014 16:36:24 GMT
Yes it's an AA but i just call it a Model A as not many people know the difference
The rear suspension didn't really have any travel because the springs were huge, it's just designed for carrying weight were as most model A's including pickups you see are based on car chassis and this is much much more heavy duty
