ben-dover
You can't polish a turd, but you can roll it in glitter...
Hi peeps.
I have been using an A-frame to tow cars for years but twice now I have had problems towing cars equipped with a steering box. One was a Discovery and today my E28 has also refused to be towed. Basically both towed cars go onto full lock when you drive forwards, in reverse it's fine!
Was wondering if it has something to do with a steering box system not wanting to self correct?
Anyone else had the same issue? Or am I missing something???
Many thanks in advance.
bortaf
Ive had the same with FWD cars on tight corners, the diff makes the steering stick on full lock, not towed a SB car TBH but i recon it's probably to do with the castor angles used, modern cars tend to have P/S and so have a lot of self centering action due to a lot of castor abgle, maybe SB cars have less ??
R.I.P photobucket
ben-dover
I spose i have been lucky so far with fwd cars, not had them do that and I have towed a lot! With the SB cars they full lock as soon as you pull away. It's damn irritating when your in Brighton wanting to tow a car to Essex The real annoying thing is that a friend tows an SJ410 with one and doesn't have a problem! Mr Ackerman has a lot to answer for!!!
Last Edit: Nov 2, 2014 16:20:42 GMT by ben-dover
Never had a problem A framing 4x4's (Range Rover, Disco, Defender, Series, Fortrak, CJ5 and my current Mahindra MM540). However Citroen Xantia was a PIA (suspension had to be on highest setting) and a Mazda 6 proved impossible to A frame as wheels kept going from full lock to full lock. Even somebody sitting in the car and engine running (for PAS) couldn't stop the wheel violently moving to full lock when even the slightest forward movement.
Hi I don't tow myself so might be useless but with you having problems on different cars could it be a fault with the wishbones/ rubbers / ball joints on the cars in question rather than the apparatus.
sweaty palms slip off joystick
^ wise words about the law, last time I checked you were ok to A-frame as far as you wanted to a place of safety but things might have changed.
We A-framed the Hunter - with SB & a very worn suspension bush - many miles with no problems when I bought it. Not sure anything would swing left&right, most cars have a built-in self-centering geometry.
joe90
Yorkshire and The Humber
Could it be where your fastening the a frame to the vehicle causing the problem?, I've towed Mk2 a 3 transit's with no problems and also landrover's with no issues.
Bryan
ben-dover
Thank you for the heads up regarding the changes in laws, very interesting read. Might have to up-date with a breaking system! Thinking about it could it just be the fact that there was excessive toe-out? Just noticed both inner edges on the front tyres on the towed vehicle are heavily worn, just a thought...
ben-dover
[quote and a Mazda 6 proved impossible to A frame as wheels kept going from full lock to full lock. Even somebody sitting in the car and engine running (for PAS) couldn't stop the wheel violently moving to full lock when even the slightest forward movement.[/quote]
That's exactly what's happening to me.
ben-dover
I was thinking about trying a different location point but its not easy on an E28. Could it be because the "pulling point" is in front of the centre line of the front axle??? When set up on other vehicles it sits nicely at the rear of the wishbones, behind the centre line. Sounds stupid but only thing I can think of at this point of an evening.
Scratch that, have seen plenty of motor homes pulling cars towed from the very front with adapters on the bumpers. Irritating!
If you read the whole thread things are not as clear cut as first thought....
A few vehicles will not tow with an A frame.
They steer counter intuitively , going onto full lock at the first opportunity. A real pain.
The only answer I have found ,in those circumstances, is to ratchet strap the steering straight.
It will then tow fine in a straight line, but turning, at a junction , or a roundabout, is a real hassle, with mucho squealing and oversteer.
Doable though. I've pulled big old lumps from all over Europe using strapped steering. Just go VERY slowly.
bortaf
Or just leave the steering lock on ?
R.I.P photobucket
ben-dover
Thanks for your input people.
I thought about strapping the steering straight but the idea of having to tow at 56mph (to keep up with hgv's) on two different motorways, in the rain, with a trailer that wants to push you straight all the time kinda scary. Luckily my mate said he would help me tow it back with a ridged bar next weekend, several pints will be exchanged as payment!
Never had any luck towing a bmw on my a frame lol Had a 520 e34 behind my big transit and they parted company lol
Never had this before? Did try and a-frame an MGF on the weekend, but the arms wouldn't clear the frame under the spare wheel section. It says on VOSA website that any car on an aframe is classed as a trailer.
Last Edit: Nov 4, 2014 9:06:35 GMT by DavidB
bortaf
Never had this before? Did try and a-frame an MGF on the weekend, but the arms wouldn't clear the frame under the spare wheel section. It says on VOSA website that any car on an aframe is classed as a trailer. Which meens if over 750Kgs it has to be braked, that's the sticking point, i only use/get away with it as i use mine to tow bare shells to the paint shop or punt them from garage to garage while i " get round to working on them" I used to use the Aframe all the time transporting cars about the country till i got pulled a few times, fortunatly it's a grey enough area to get away with it if your lucky but in London getting lucky is getting harder
R.I.P photobucket
kevfromwales
the conrod's REALLY out the block now!
Thread from the dead bump for this one.
Now I have used A frames (irrespective of legality) for many, many miles, and many different old shonkers, but had a right weird one this morning. A couple of young lads came into work last night asking me to help them move an old bmw. Turns out they scored an e34 525i for PENNIES. Dragged it on a strap no problems, but hitched it to the a frame this morning, and when you turn right, the e34 does a hard left!
Very weird indeed.
I'm going to have another bash later, by hooking the a frame around the back of the wishbones rather than the front (they are like a boomerang shape), but anyone experienced anything like this before? Its a non runner btw, and a steering box
Kfw
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
May 31, 2016 10:30:48 GMT
I worked in the hire game a few yrs ago,we rented towing A frames out,it said in the hire guide not to be used on Citroens and BMW's ... Then a whole world of legal hurt got involved,so they got taken off the hire brochure.
