Fungus
Just a quick question;
When installing twin DCOE's, is the spacing of the carbs/distance between them an issue?
I'm designing a manifold and can't seem to find this info anywhere.
Thanks
Fungus
Thanks for the reply.
So is there a 'standard' size of linkage? The one in the pic looks like it has a certain degree of tolerance in terms if spacing.
Thanks
Oct 24, 2014 12:28:53 GMT
Would it not be less hassle just to get one made? Try danst engineering they do this sort of thing for a living
Sent from my GT-I9505 using proboards
Fungus
Oct 24, 2014 12:49:38 GMT
Would it not be less hassle just to get one made? Try danst engineering they do this sort of thing for a living It would probably be easier yes, but I'd like to make one.
Last Edit: Oct 24, 2014 13:15:57 GMT by Fungus
Oct 24, 2014 14:25:38 GMT
I will measure the distance between the center ports for you when I'm next down at the workshop
Fungus
Oct 24, 2014 15:11:26 GMT
Thanks a lot, that would be a great help. You could always measure the distance between the mounting bolts, might be a bit easier.
Darkspeed
Club RR Member Number: 39
Twin DCOE spacingDarkspeed
@darkspeed
Club Retro Rides Member 39
Oct 24, 2014 17:21:59 GMT
The synchronising linkages come in different widths - just the length of the "tang" on one of the pair - if you have the skills to make a manifold adjusting the centre linkage would be a walk in the park. I think I have two or three pairs of varying widths in the Weber bin.
Fungus
Oct 24, 2014 17:31:30 GMT
I did wonder whether that was the case. I'm guessing the 'tang' is designed with this in mind, as it doesn't seem to have a solid connection (looks to me as if it just slips in between the two screws).
Thanks for the help.
