joda
I bought a car at the weekend, its just a shell, no engine, box, rear axle. the Vin plate is missing, but it does have a REG plate front and rear, as well as 3 part mouse eaten tax discs.
Looked at the DVLA website for a V62 Form, but it asks for a VIN number or the application will be returned.
Is there anyway i can apply for a log book?
DVLA vehicle status check says it was last taxed March 2004
thanks
kenb
Oct 20, 2014 11:34:59 GMT
Officially no, but I'm sure someone will be along that can HPI it for you. Got to love our red tape system.
Oct 20, 2014 14:39:36 GMT
You could always buy a vin and v5 from ebay and not tell anyone...
Legally I would have thought it would have to be a Q reg.
Oct 20, 2014 17:50:37 GMT
It can be worth a try filling out a V62 form without the reg number, and putting a covering letter in explaining that you do not know the reg. I had heard this could be done on motorbike forums and have done it myself twice with success (again on motorbikes, but I can't see that making a difference)
My covering letter also gave the year of manufacture and date of sale, I got the V5 through a couple weeks afterwards.
Otherwise I'm told the police can look it up. My plan had that not worked was to go to the station reception when it was quiet and say I was considering buying it, could they please check it wasn't stolen, then ask for the reg when they had the details up.
[edit] oops, misread your post. Thought it was the other way round. Still may be worth sending off a V62 and covering letter.
Last Edit: Oct 20, 2014 18:05:53 GMT by tristan
Oct 23, 2014 12:35:17 GMT
Depending on the age of the car it should have the VIN number stamped into the chassis or bodyshell. Find out where it is likely to be stamped and get looking.
1995 Range Rover 4.0 1995 BMW 320i Saloon 1989 BMW 325i Touring 1991 Mercedes 300TE-24 1991 Mercedes 190e 1970 Sunbeam Imp Sport
1966 Valiant 200 Custom 1964 Ford Fairlane 500 Station Wagon
`state
Yorkshire and The Humber
Oct 23, 2014 13:35:46 GMT
Cant you do one of those cheap checks done by text that cost about 3 quid? Should bring the vin up.
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
Oct 23, 2014 13:53:43 GMT
Cant you do one of those cheap checks done by text that cost about 3 quid? Should bring the vin up. They don't give you full vin, just last 4 digits
Oct 25, 2014 21:13:20 GMT
If the car is pre 1981 then yes you can be filling in the form and writing a cover letter to explain the riveted on VIN plate which had rusted away has been lost although they may want to check the car and without any running gear you are in murky water.
Oct 26, 2014 19:09:43 GMT
i had a austin a50 a few months back that had been sat 20 years i applied for a v5 with the v62 form and left the vin part blank and they sent me back a v5
Oct 27, 2014 18:17:49 GMT
If the car is pre 1981 then yes you can be filling in the form and writing a cover letter to explain the riveted on VIN plate which had rusted away has been lost although they may want to check the car and without any running gear you are in murky water. when you say "murky water...." my car hasn't got a VIN atm either and ive swapped engines and done a lot to it....! is that something I should worry about when I apply for a log book? :s
Oct 27, 2014 19:19:47 GMT
Cant you do one of those cheap checks done by text that cost about 3 quid? Should bring the vin up. They don't give you full vin, just last 4 digits It shouldn't really be difficult to figure out what the chassis number should be given the last 4 digits. I've had loads of bike log books through in the past without putting the frame number down. Even managed to get a logbook from the frame number with only a partial number plate (all the last owner could recall)
Oct 27, 2014 22:12:03 GMT
If the car is pre 1981 then yes you can be filling in the form and writing a cover letter to explain the riveted on VIN plate which had rusted away has been lost although they may want to check the car and without any running gear you are in murky water. when you say "murky water...." my car hasn't got a VIN atm either and ive swapped engines and done a lot to it....! is that something I should worry about when I apply for a log book? :s Yes because if you can't prove the origins of the car it MAY require a SVA (or whatever they are calling them this month) which will result in a Q plate being issued. One way of proving the age and origin of a car is having the original engine when you say 'done a lot to it' what do you mean?
Oct 28, 2014 17:51:58 GMT
I still have everything from the car atm.... but its all stripped out' suspensions been modified, completely new fuel system fitted... :/ there's no denying the cars age though haha its in a bit of a state!
joda - How did you get on with this? What did you buy this time?
