93fxdl
Enter your message here...
Oct 13, 2014 11:15:46 GMT
Having now collected the spaceframe for the sandrail build, its time to prepare for painting, but first I want to blend all the joints, any high points in the welds will get sanded back, then blended with filler. Should I fill onto bare steel or primer first ? The frame in question If I have added the right picture Ttfn Glenn
Last Edit: Oct 13, 2014 11:32:20 GMT by 93fxdl
Iain
Oct 13, 2014 12:08:36 GMT
I would (have) personally use a brushable seam sealer over joins and welds, which fills in the low points and makes them look presentable. Imagine it'd be a little more flexible too.
Copey
Oct 13, 2014 21:09:03 GMT
personally i'd go for a decent quality etch or zinc primer before doing anything and then can seam seal as suggested above or fill it etc
Oct 13, 2014 23:16:10 GMT
I was always led to believe filler adhered to metal better than than paint/primer, that's what is was designed for. Am sure some body shop experts will confirm.
93fxdl
I was always led to believe filler adhered to metal better than than paint/primer, that's what is was designed for. Am sure some body shop experts will confirm. Thats what i had heard, hence the question Ttfn Glenn
93fxdl
Can't do multiple quotes, Would seam sealer give a good finish, be rubbed down ? Plan on using a good primer, probably a coloured one to give the Tunis yellow a bit more glow, Ttfn Glenn
