EmDee
Committer of Autrocities.
Club RR Member Number: 108
Oct 12, 2014 10:25:17 GMT
Looking for a bit of a favour here folks. I'm after the dimensions of the rear window of a mk1 Fiesta. In fact, it might be the same as the mk2? Anyone know? I have no idea - because quite obviously I don't own one. So if any Fiesta owners could possibly supply me with the rear window dimensions I will supply you with ONE MILLION INTERNET POINTS. And possibly even some biscuits. The dimensions I need are height from top to bottom, width of the top and the width of the bottom. Any takers? Thanks
Last Edit: Oct 12, 2014 12:37:49 GMT by EmDee
EmDee
Oct 12, 2014 12:05:32 GMT
Just realised this should be in the Question Section. What an idiot. Mods - feel free to move it appropriately, humble apologies!
lusciousthelock
Who needs brakes? They only slow you down!
Oct 12, 2014 12:36:17 GMT
Not sure on size as it's been a while, but I'm sure mk1 and mk2 are the same. I know the tailgates for each can be swapped complete.
EmDee
Oct 12, 2014 12:38:55 GMT
Not sure on size as it's been a while, but I'm sure mk1 and mk2 are the same. I know the tailgates for each can be swapped complete. Thanks Mr. Lock, thought they might be, thread title amended appropriately Also want to add that I'm not too worried about the hieght, more the width at the top and bottom. Thanks all.
Last Edit: Oct 12, 2014 12:39:49 GMT by EmDee
Oct 12, 2014 18:00:28 GMT
Oct 12, 2014 18:15:02 GMT
Allowing for a little under the rubber, I make it;
90cm across the top 112cm across the bottom 62cm top to bottom
But I wouldn't want to make one from these measurements.
What are you up to?
Oct 12, 2014 20:08:16 GMT
Just measured my mk1 face lift and my Mk2. Came up with the same measurements on both,although the Mk2 screen does appear to be more curved than the almost flat Mk1.
Last Edit: Oct 12, 2014 20:09:28 GMT by inspektor
EmDee
Allowing for a little under the rubber, I make it; 90cm across the top 112cm across the bottom 62cm top to bottom But I wouldn't want to make one from these measurements. What are you up to? HERO!!! Thank you soo much! PM me your paypal address and I'll gift you some biscuits mate. Might even tell you what I'm up to Just measured my mk1 face lift and my Mk2. Came up with the same measurements on both,although the Mk2 screen does appear to be more curved than the almost flat Mk1. Thanks for verifying inspektor, much appreciated
Last Edit: Oct 13, 2014 9:32:00 GMT by EmDee
Oct 13, 2014 16:42:18 GMT
Might even tell you what I'm up to My wife would like to know too. When she caught me out there measuring,she asked what I was doing? "Measuring glass" I said. Then she asked why? My reply was "I don't know" She should shook her head at looked disapprovingly.
EmDee
Oct 14, 2014 10:36:32 GMT
Might even tell you what I'm up to My wife would like to know too. When she caught me out there measuring,she asked what I was doing? "Measuring glass" I said. Then she asked why? My reply was "I don't know" She should shook her head at looked disapprovingly. Bwahaha this has made my day!
colnerov
Oct 14, 2014 14:30:34 GMT
Women! They just don't get it, do they?
Last Edit: Oct 14, 2014 14:31:48 GMT by colnerov
landyman1
escapee from main dealer sweatshop,now twirl spanners for electricity industry happy days
Oct 14, 2014 21:15:02 GMT
>:Dhi not wanting to burst your bubble but back in the day one of the body lads at a ford dealer I worked at was replacing one,both are very slightly different,resulted in a glue it back together situation .
EmDee
Oct 14, 2014 23:14:09 GMT
>:Dhi not wanting to burst your bubble but back in the day one of the body lads at a ford dealer I worked at was replacing one,both are very slightly different,resulted in a glue it back together situation . Thanks for your concern. Happily this will not present a problem for me. Not owning a Fiesta is helping with this considerably I'll reveal my motives tomorrow once I've got a conclusion to the saga
EmDee
Jan 14, 2015 21:27:07 GMT
FINALLY!!! Can't thank you both enough for the measurements, the two cars are close enough (this is for a Polo).
