Potsy
Looking for some help and advice on finding some repair panels for a 1990 Porsche 944.
The car has failed mot on corrosion and further inspection shows it's going to need an inner, outer and rear arch corner sections.
Does anybody here know where I can find replacement parts online?
Hoping this car can be saved as it's a 1 owner clean (ish) example.
Many thanks in advance
Gary.
I'd probably start in the States... Pelican parts or similar. There is a few forums 944 owners...Tipec that might be able to help this side of the pond. Also Roger at 928's RUS in Texas might be able to give a lead.
Geoff
I would be rich if i had not spent so much money on Cars and fast women...oh, i did waste some of it as well!
hallsy
Oct 10, 2014 14:24:49 GMT
The OE outer sill panels are still available from OPC, although I'm not sure if they currently have stock of both sides as they had supply issues in the past. I also believe some of the inner panels are available, but most people fabricate their own repair panels for the inner parts as necessary.
For the outers Elliot at PorkaParts also sells pattern panels for both the sill and rear section.
OPC would be my bet, but as said they do make them in batches. Being genuine it should fit and hopefully last! As Hallsy said the inners tend to be made up by people.
Oct 24, 2014 14:13:59 GMT
Could you not get some "cuts" from one of the porsche breakers?
