Anyone able to shed any light on this?
I have the fixings and the ball joint mounted rod disconnected on the lights, plastic surrounds and metal top part removed,but it seems as though the adjuster - where it pokes through the front panel - is stopping the light from coming out. That, or the motor being bolted to the bracket, but I can't get my hand in enough to remove those two bolts.
Is there a more obvious way?
The front bumper and wings should come off fairly easily, after that.
They look very similar to the mk2.
What about the rear bumper, where are the fixings?
All I have seen so far are the half a dozen bolts on the underside, going into the bumper reinforcer bar.
I need bolt grips to get these out, though.
Any links to (working) guides appreciated.
