I have for sale one 1930s LWB Austin 7 project.
This requires complete rebuilding as it is currently an assembly of parts.
The parts are thus:
1 LWB Chassis (looks like mid-30's, no V5/ID)
Rear axle, with hubs, brakes and rear end of prop
Front axle, with hubs, brakes and steering arms, with stabiliser bars attached
Engine block with valves
Sump, water inlet, water outlet, 4x connecting rods, 2x pistons with connecting rods
manifold, Zenith carb, Engine crank-case and crankshaft, camshaft with engine gear
short nose, starting handle, dynamo mount, dynamo, DK4A distributor unit, tappet cover
3 speed gearbox, clutch housing, clutch cover, starter motor, prop front half
front spring, 2 rear springs, 4x wheels
there are two small seat squabs, rear seat upper and lower squabs, and one chummy front seat (needing repair)
bonnet with side panels
steering column with box, complete with inner adjustment control rod, steering wheel
Lucas ignition switch unit, horn, 2 ignition coils.
Location is Dungannon, Northern Ireland. 07749520510. price is £2995.
The parts are thus:
