the earlier XUD clutches use a vastly superior "pull" clutch, rather than the HDi "push" clutch (ie: what almost every other car uses) The pivot point is different, meaning more clamping force, for the same release force - but you have to pull the centre of the clutch out to release, rather than pushing it in. I found this out the hard way by fitting one - only to find it would never ever release
tim124
"The pivot point is different, meaning more clamping force, for the same release force - but you have to pull the centre of the clutch out to release, rather than pushing it in." Not so sure about that,the has to be a trade off, low clamping force = less release force,& high clamping force = more release force? lever pivot point would change the distance traveled, so the pull clutch must have more movement.
taken from page 46 of Advanced Vehicle Technology (2nd Edition) by Heinz Heisler Awesome book, really worth a read if you can get a copy
explains the xud9te clutch coping with more torque than dw10
I was quite surprised when I found out about the pull clutches too tbh - They look like a nice mild upgrade for most clutches too. Apparently good for approx 300lb ft, even on those small friction plates.
tim124
Interesting stuff,it would be no big deal to convert to a "pull" clutch if flywheel size was an issue..
Last Edit: Aug 7, 2014 21:02:12 GMT by tim124
tim124
Well, I now have a HDI Flywheel & new cover plate @ £30 the pair, picked up a new Sachs driven plate for £22.50, thanks for all your help!
