820
Jul 26, 2014 12:49:01 GMT
Hi, I had some welding done causing the underseal and paint to burn off under the car, the bare metal has begun to rust so I need to clean it up and underseal it. Plan is to treat the metal with a rust treatment then underseal over that. Are the rust treatments any good? which is the best? and any recommendations or tips would be great, thanks Jim
ChrisT
Club RR Member Number: 225
Jul 26, 2014 13:04:10 GMT
If it's only just been done it'll only be surface rust, should come off/clean up easily with a wire brush and underseal straight onto it I would have thought. If you want to treat it with rust inhibitor I've found Dinitrol RC900 very good. www.frost.co.uk/automotive-rust-products/dinitrol.html
taurus
Jul 26, 2014 21:21:06 GMT
I have also used the Dinitrol products and found them pretty good. I actually use the RC800 which comes in a 1 litre container. It's expensive but a litre goes a long way.
ferny
Club RR Member Number: 13
Jul 27, 2014 10:01:31 GMT
820
Jul 27, 2014 15:28:17 GMT
Thanks for the links, the Dinitrol product range looks good, an outer sill also needs a dent repair, this has an undersealed texture, painted in the car colour, I might be able to find that on there to. cheers
