Jul 14, 2014 12:37:22 GMT
Hi I'll try and keep this short Got leaf springs on the rear if my car, want to lower it by 4" but researched and lowering blocks don't seem the best option, if they'd work atall!
Anyone have any suggestions please?
Cheers
Craig
Copey
Jul 14, 2014 12:45:40 GMT
Does the axle sit on top of the leafs? If so and if they are single leafs you could get them decambered so they are flatter, if that doesn't give you the desired lowness you could then add lowering blocks
Jul 14, 2014 14:44:36 GMT
Yeah.... Where could I get that done?
Cheers
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Jul 16, 2014 23:33:44 GMT
google should bring up somewhere,.
facebook: rodney dean / rd transport
lowering help!!!!ChasR
@chasr
Club Retro Rides Member 170
Jul 16, 2014 23:41:24 GMT
What car is it?
There are a few firms who will decamber springs at a reasonable rate.
Last Edit: Jul 16, 2014 23:41:51 GMT by ChasR
Jul 17, 2014 11:48:27 GMT
Hillman hunter... I looked at decambering but its about 60 pound a spring. I'm trying to do it on a budget.
Put them in the 5 ton press at work, but it didn't make a difference. Had them bent the opposite way, but they just went back!
@chasr
It is easy for me to say this (and to spend someone else's cash) but this is one area I would splash out on, regardless of the car. Naturally, the caveat is that it is a car for keeps. I say this as besides making the car a safer place to be, it is surprising what new suspension can do.
On my MGB which had new rear leaf springs (albeit 10 years old (I had not driven the car for over a 6 year time period and they only had around 500 miles on them), my attempts at regreasing and re oiling them were futile (they did move, just not very well!). Putting on the decambered items not only improved the handling but also the ride by a long shot (I used to avoid roads with speed bumps prior to me lowering it! The rear end did move, but not alot). No amount of jacking the car down hard or greasing would loosen off the old springs. The above changed my perspective on how 'bad' (or rather no so bad) leaf springs can be despite the naysayers acting as if they are the spawn of Satan (whilst they may have a point, that reputation is not fully deserved).
Last Edit: Jul 19, 2014 11:14:34 GMT by ChasR
Copey
Jul 19, 2014 10:23:59 GMT
£60 a spring isn't a bad price, far better option than blocks too, especially if you're wanting a big drop, plus you have already said you don't really want to use blocks, they are really your only 2 options
Jul 20, 2014 12:52:24 GMT
yeah but I'm guessing I will have to use lowering blocks anyway? everywhere ive looked, people don't recommend more than 2" of decambering
RobinJI
Jul 20, 2014 13:08:05 GMT
Neither decambering or blocks alone are likely to give a safe 4" drop, your best bet will be to use a combination of both, with the proportion depending on how cambered the leaves are to start with. Shortened shackles would help too depending on the length of the originals.
Have you looked at Seth's build thread for his Minx? I'm not actually sure what method he's used, but his car's likely at the sort of height you're aiming for.
Last Edit: Jul 20, 2014 13:13:15 GMT by RobinJI
Jul 20, 2014 15:10:17 GMT
brilliant! thanks for the help guys
Jul 20, 2014 21:19:43 GMT
Neither decambering or blocks alone are likely to give a safe 4" drop, your best bet will be to use a combination of both, with the proportion depending on how cambered the leaves are to start with. Shortened shackles would help too depending on the length of the originals. Have you looked at Seth's build thread for his Minx? I'm not actually sure what method he's used, but his car's likely at the sort of height you're aiming for. Well if you look at this one - only lowered 2" inches using blocks. Can't imagine it being drivable with 4" drop. retrorides.proboards.com/thread/139435#.U8wxjvldXsY
Last Edit: Jul 21, 2014 7:30:33 GMT by code109
Incidentally, I saw that hillman hunter lowered 2" on Google, and that is how I found this forum, and what made me buy a hunter
Seth
To decamber the springs on my estate I had to dismantle the leaves and do every one of them, a bit of a time so they all conformed to the new shape before re-assembling. This is the decambered four leaf estate spring against the standard 3 leaf saloon spring I had been running for a bit. Think I got about 1 1/2" but you need to make sure that you don't go too far and end up with springs that bend the wrong way when loaded. It might look more than that in the photo but it's just the angle/lighting.
I didn't even think of that until.you said! :s
I've taken the middle leaf out and put the shocks on their hardest setting and got 2" of drop. Didn't think about the springs popping up the opposite way though....!
