(and chappettes!)
the brakes have a 67% differentiation, so i assume that means one brakes harder than the other. its a 89 estelle, and i want to know what I'm supposed to do in order to fix it?
Its a serious imbalance between the sides, one is working well, the other not... Was it front or rear that failed, and does the sheet show the effort applied at each wheel? Will probably be a stuck caliper (front) or out of adjustment drums (back) So once you know which one is causing the problem, strip, clean and rebuild as per the haynes comic
m4rtin
1982 volvo 343 & 2004 rover streetwise
rear brakes or front? .. if the back could be a worn set of shoes on one side, maybe the spring even. on the front i guess it could be down to the hoses/pipes or a sticky caliper, or just one set of pads more worn for whatever reason
SteveP
300 Maniac
Thow another variable in... brake distribution valve? But I gather that your Estelle has sat unused for a bit? So points more towards adjustment/sticking etc.
2003 - Volvo S60 D5 SE (Daily) 1989 - Volvo 360 GLT 1985 - Volvo 360 GLS
load distribution valve works front/rear not left/right.... that would be bleeding dangerous at best!
sorry fellas, its the rear.
i do however have to also do the brake pipes at the front. not the easy and short ones neither...
3 weeks to keep the reduced fee for retest, and not have to worry about the other guff. and I'm going to spend my days off in that period in englund. great.
so if its sticky shoes/spring, i'm going to have a lack of fun. hands up who's removed an estelle drum/hub?
thought not.
got sheet. it says: "You are a monkey. Fix your car proper like." below that it says: Emissions Co @ idle 3.240% out of 3.50% or less HC 411ppm out of 1200 or less. (mums and my fav estates both had less than 0.1ppm btw) PASS Headlamp Aim Pitch: Offside: OFF SCALE (gonna do it, do it right ) Break Point (wazzat?): Offside: Too far right FAIL Brake Test Axle 1: Brake Effort: Nearside 2.03kN, O/S 1.58kN Imbalance: 22% out of 30% or less Axle 2: Brake Effort: Nearside 0.75kN, O/S 2.11kN Imbalance: 64% out of 30% or less Other defects: Stoplamps inoperative Horn inoperative Nearside Rear Shock loose Brake pipes N/S, O/S front pitted/corroded gah!
m4rtin
if your gonna fail at least you did it properly and didnt just fail on a minor point lol. id check all the brakes anyway while your at it, 22% this year may be 30% next
Check everything else first but one other thing it could be could be the brake pipe corroded inside restricting the flow. Ive known that cause an MOT fail due to imbalance and I was on ages working out what the problem was. That was on the front brakes on a G reg favorit back in 1998
I once failed on something like 60% difference.... took apart both rear drums, new shoes, cleaned up the drums, greased the pins and stuff. Managed to make the good brake just as bad as the bad one, which is still a pass!
berendd
could be a broken brake cylinder in the rear...
or a brake cylinder that has been changed but spilled some fluid on the shoes..
Smiler
I once failed on something like 60% difference.... took apart both rear drums, new shoes, cleaned up the drums, greased the pins and stuff. Managed to make the good brake just as bad as the bad one, which is still a pass! I just spat my beer over the computer after reading that! It does go some way to explaining how my old VW Camper managed to scrape through some of it's past MOTs.
