Need the aforementioned front uprights/legs with abs so I can use the early type Bilstein inserts I managed to aquire recently.
can be identified by the smaller 19 mm top nut, as opposed to the later 22mm type.
going on a 525 tds, I have two sets of springs etc, so anything not bent will suffice, springs can be as rusty as you kikd and dampers pissin oil.
