My cheap exhaust driven turbocharger does well enough, and doesnt require additional charging or more heavy batteries, thank you very much
Electric turbo/super chargers Robinxr4i
@robinxr4i
Club Retro Rides Member 143
Can't see a problem with it personally, anything that increases output is good with me. I'd imagine under bonnet and intake temperatures would be much less than a typical exhaust driven turbo charger. From what I understand the turbochargers on the new F1 cars can be spooled electrically then proceed to be driven off exhaust gas once the revs are back up.
Jun 15, 2014 14:22:53 GMT
retrowrongun from little acorns do great oaks grow. And this is still in the early stages of it's life and with anything new it will have it's hiccups in the early stages but will develop and be more practical(along with being cheaper) later on! A bit like the LPG systems when they first came out, and look at how many of us are fitting the latest developing kits of lpg into our vehicles.
Somebody has had the idea, and has taken the plunge into developing the idea into a fully functional reality for us and not just the F1 cars. How and and what this will develop and what it will be like in a few years is the question!
bortaf
Jun 15, 2014 14:39:11 GMT
Well if it's good enough for F1 i spose it can work on the street, however the same old recharge and storage problems will still limit it, 1 to 8 use and recharge cycle sounds good but i bet that's under ideal curcumstances and not real street tested, add in the extra battery/s and a larger alt (probably water cooled due to it's new duty cycle) and the extra cooling that will require from the cooling system and it all starts to get way more complicated than it first seems.
R.I.P photobucket
Jun 15, 2014 16:03:30 GMT
nice vid about them from mightycarmods
Range rover Classic tddi
jonomisfit
Club RR Member Number: 49
Electric turbo/super chargers jonomisfit
@jonomisfit
Club Retro Rides Member 49
Jun 15, 2014 17:42:46 GMT
Turbo's make good use of the waste heat and flow in the exhaust gasses so nicely make use of this to compress the intake charge. Nice piece of thermo.
Genuine electric compressor would use a fair bit of energy from a battery but would be able to give you exactly the boost curve needed to give good power at all times.
To me, making use of an electric motor to spool the turbo when off boost, then letting the exhaust gasses drive it when the exhaust flow is high would be best of both worlds.
Intake temp wise a lot of this comes from the compression of the intake air, not transmitted heat from the compressor. You'd still need an intercooler etc.
Need to be a pretty powerful motor to spin the compressor at required turbo speeds.
Pages bookmarked for a proper read :-)
Jun 15, 2014 18:20:57 GMT
Look at the episode of Roadkill where they fit a few leaf blowers to a Monza an take it to the dyno. Imagine the amount of air that this small fan must be able to move to do anything more than just obstruct the air flow to the engine.
If it was this easy to gain 50 hp why do car manufacturers spend all that money on ordinary turbo chargers?
jonomisfit
@jonomisfit
Jun 15, 2014 18:44:55 GMT
A fan is not a compressor. A fan moves a large volume of air at low pressure (as in leaf blower) where as a compressor moves a relatively small volume but increases the pressure across the device significantly.
This one is significantly different to the intake fan type kit.... its a 3kw motor for a start. Not saying its really any good in a practical sense though.
Turbo chargers are (relatively speaking) cheap systems for OEM's.
I'm sure they'd put a lot more interesting things on cars but people wont pay for them.
Jun 16, 2014 19:54:45 GMT
I would say that these particular blowers will work - Brushless motors are insanely powerful for their size, and this thing seems to feature a custom brushless motor, and has the proper controller and batteries to back it up, it draws over a hundred amps FFS! I would definitely give one of these a go. It's actually got me thinking about trying something similar myself, but I don't think there's a brushless motor off the shelf that'll spin fast enough for reasonable money.
Last Edit: Jun 16, 2014 19:57:05 GMT by cobblers
bortaf
Jun 17, 2014 12:38:07 GMT
That artical just doesn't read right or is it me? not the car but the writer? just comes accross like he doesn't actually know what the writting about or hew's dumbing it down (too far) ?
R.I.P photobucket
Nozza
I have an avatar!
Jun 17, 2014 16:27:37 GMT
My annoying two penneth, How much power does a normal supercharger take from the engine in the form of its drive belt, in order to compress the air and shove it in the intake at whatever boost pressure it is running. Now for an electric supercharger to give the same kind of boost that power needs to be converted from mechanical energy to electrical energy by the alternator, sent down wires, and then converted back to mechanical energy by the electric motor. Unless its some sort of perpetual motion you cannot create or destroy energy only transform it into another form of energy. I can imagine you would need a massive alternator, nice thick power cables and the kind of blower fan that you would see on an industrial air conditioning unit.
Last Edit: Jun 17, 2014 16:36:59 GMT by Nozza: Have a nice picture of a Volvo that I've stolen from facebook.... It's nice isn't it?
Rusty Deathtrap on Mercedes-190.co.uk
Jun 17, 2014 16:46:24 GMT
The article , however poorly its written , is saying that it has some sort of electrical fan , but its feeding a existing turbo , its not just a fan on its own , as stated above , they do not move pressured air , just a high amount at low pressure .
So a fan may work if it was particular strong and feeding a turbo , not on its own as the air will not be compressed enough .
Also, a turbo, in essence, is only a fan - as long as it's being driven at the correct speed, with enough force to allow it to continue shifting air at the rate it "wants" to, it doesn't care whether it's powered by exhaust gas, petrol, diesel, electric, or a million hamster wheels driving a step-up gearbox Only drawbacks to a 'leccy turbo (centrifugal supercharger in this case, technically) is the electrical charge needed, and the expensive motor+gearbox. But starting off with a centrifugal supercharger is a good start for a homebrew version
jonw
Can open a Mouse with a File
Jun 18, 2014 11:46:21 GMT
How about this for auxiliary driven superchargers. Fell LocomotiveHad Four engines, each pair of engines was fed from a supercharger driven by a smaller auxiliary engine governed to give a constant flow rate to the engines.... that's 6 engines!!! This didn't work very well either......
Suzuki SV650R The good Triumph T20 The Bad BMW G650GS The Ugly Matchless G12CSR The Smokey Toyota Hybrid One pint or Two?
Ingredients of this post Spam Drunken Rambling of author Bad spelling Drunken ramblings of inner voices Occasional pointless comments Vile beef trimming they won't even use in stock cubes
I based my 3rd year dissertation on this, essentially it was very plausible but only in certain conditions. I based my work around a small engine'd hill climb car so the super/turbo charger didn't have to run for long periods of time.
Last Edit: Jun 20, 2014 9:37:30 GMT by mgbizzle
