I've got here a Grundig WKC5300RDS radio/cassette head unit, with hideaway DAB box (DCR200DAB) and MCD36 6 disc CD changer.
I bought the head unit and DAB unit from a Fiat dealer, they were I believe offered as an upgrade on some cars from 1998. I got the CD changer some time later. I've tested them today and they all work, the CD changer and DAB unit have some marks from being installed in the boot, the headunit is good. They come with instructions for all three, and the cage for the HU, but no removal keys. The original case for the removable front panel is missing, but there's an aftermarket one. The keycode card is also missing, but this feature is turned off so the unit works fine (just don't turn the feature on in the expert menu!).I can't find the mounting brackets for the CD, I've always had it mounted to the boot carpet using velcro and the DAB unit is secured to the top of the CD using high temp & strength tape.
The head unit is 4x50w max power output, and has a variable colour display to match into your dash lighting.
I'll also include a Panorama glass mount DAB aerial, but this is untested as it's not mounted on a car, but it worked OK when last used about two years ago.
I'm looking for £60 for this set-up, and I'm in South Linconshire (PE12 postcode). I'd prefer pick up but could parcel up gien a bit of time.
07986 971692
07986 971692
