Hi Folks, up for sale is a set of TA-technix coilovers to fit a mk1 Mazda MX5 / Eunos Roadster.
Despite looking a bit grubby, they have only done around 1000 miles on the road (and no track use). They were fitted to a friend's car which failed the MOT quite spectacularly (blew the rad in the test bay), before sitting over winter unused before he decided to scrap it. I was planning on fitting these to a potential MX5 purchase, but the one I ended up with already has coilovers on it, so these aren't needed.
They come complete with C spanner (not pictured) and the top mounts as shown, which aren't included with new sets. This set is therefore pretty much ready to bolt into your car. All the adjusters are free/easy to rotate. At present one of the fronts is missing the nut at the top of the shaft, but otherwise they should be good to go.
Edit: according to eBay, specs are:
Front -20mm to -60mm
Rear -30mm to -60mm
I'm looking for £120, I'm based in Bristol but I often travel to the Midlands, Milton Keynes and various other places for work, so may be able to offer some form of delivery, I could post them at cost, or I could leave them at Area:52 if that helps anyone (and if Bruce doesn't mind).
Rear -30mm to -60mm
