Apr 20, 2014 19:14:33 GMT
ok, so i bought a car last year with a load of audio in the boot. It consists of: Pioneer 1000w TS-W306DVC 12" Sub, 1000w max 400w nominal. www.pioneer.eu/uk/products/archive/TS-W306DVC/page.htmlAmerican Pro Bass Machine Amp 400w, 2ch bridgeable, www.americanproaudio.com/vs-14xx.htmlAmerican Pro Power Cap "Poweramper" 1.0 farad I wouldnt mind giving the install a go, however: a) what do i do with the power cap and do i need it? b) is the amp sufficent to run the sub well? thanks.
Last Edit: Apr 20, 2014 19:17:54 GMT by oasis6x
Apr 20, 2014 20:17:19 GMT
Power cap goes in the bin.
I would run a different amp though.
sparkyt
selling stuff
Apr 20, 2014 21:52:27 GMT
Power cap will help hold the voltage up / constant ..
Any modern amp will run a modern sub
Is the speaker 4ohm ? Your amp will only supply the current drawn by the load that is across it .
If the amp is 1000w. @ 1ohm and you put 4ohm across it you will only draw 250 w
So draw about 1/4 of what the amp can do an 1/4 of the current
Remember the earth path is more important than the supply . .
sparkyt
selling stuff
Apr 20, 2014 21:58:05 GMT
I see it can be 2 ohm or 8 ohm So wire it using both coils 2ohm . They will give you a drawing of how to do this
Run a fuse close to the batt and a second fuse close to the amp . .
sparkyt
selling stuff
Apr 20, 2014 21:58:36 GMT
Apr 20, 2014 22:12:51 GMT
One rule with audio, go simple or go all out. For what youve got, wire the sub bridged across the amp, throw the cap in as its there. Set the gain so you just cant hear a male voice on the sub.. and job done.
Paul
Apr 20, 2014 22:49:36 GMT
I wouldn't bother with the power cap...just something else to draw current.
Take on board the other points about running the sub 2 ohm bridged.
With a little application of Ohms law I doubt that amp is knocking out 500w RMS @ 2 ohm though :-(
sparkyt
selling stuff
caps don't draw current they just hold on to the peek voltage to smooth it out . ..
A second battery will do the same thing
I used to run 3 batteries in my nova when I wa a kid One 15 inch sub Two 12 inch main speakers Eight 8 inch mids Four 2 inch tweets Made my self 8 x 48w rms ic amps And ran 2 alternators
The ship rocked
sparkyt
selling stuff
I lost number plates the mirror and my rear light cluster fell out on the drive home from work
in layman's terms the power cap is a must if you wanna drop a very loud 'phat' beat, and not have your lights flash/fade in time with the music under normal in car listening conditions you'll not notice its effect...
Apr 21, 2014 11:32:17 GMT
Think I'm going to leave the power cap out tbh after reading up online. Its not going to be the most powerful setup, and it seems that the power cap actually supplies the headlights and systems as opposed to the amp when the alternator cant keep up.
Why do i need a fuse close to the amp as well as the battery? The amp has a built in fuse, and there is a beast of an inline fuse at the battery end of the wiring (ill be installing it today).
Good point on the ground wire through, thanks.
