1993 Audi Coupe 2.0 16v in red, 5 speed manual.
175k
MOT 10/08/2014
Tax 30/06/2014
Full Audi SH to 122k and loads of receipts for other stuff done recently and covering the last 7 years.
Head gasket, cam belt and water pump all done 10k ago - receipt to prove. Newis Bridgestone tyres all around. Last MOT failed only on x2 drop links which were duly replaced.
The body is still red with the only bit of marginal fading to the driver's door - I reckon a few hours on the body would have it looking even better, but she's every bit as red (if not slightly better) than the pics suggest. There's also a tiny scuff as pictured.
Faults: speedo and temp guage have literally just failed. I believe this is electrical as the bulbs behind the speedo have also given up, as has the stereo. She's also got a tiny oil leak. Last oil and filter change was 2 months ago and it's not needed any oil topping up.
She starts, drives and stops as she should and is still tight to drive.
Located in Carshalton Beeches, London Borough of Sutton - SM5 post code area.
175k
MOT 10/08/2014
Tax 30/06/2014
