Ok i will be getting my '84 bluebird on the road soon but have a problem. On the whole the car is mint as its been off the road for 20 years but being a datsun there are still a few bits of rust that are generally all over the car. Now my question is how to stop it getting any worse. My budget doesnt stretch to a full respray and i think matt black would ruin it so what do you guys think? The offending beast.
Treat the rust to stop it getting any worse, touch it up if you want it to look it's best but NO NO NO don't matt black it, it's sooo cool, please leave it original it looks just fine as it is ^^whs^^
Welcome to borrow my compressor if you want.
1966 MK1 Cortina 1971 Hillman Super Imp 1985 Volvo 360 GLEi 1986 Volvo 340 1.7 1990 Mercedes 190e 2.0 1993 Peugeot 205 STDT
79cord
Mar 19, 2014 11:13:38 GMT
As you say matt black would be wrong, though it was still common for these to be offered in '80's two tones divided at the upper door crease, such as Brown over gold. Dark grey or Blue over silver etc. which could work well. Plenty of creases to disguise partial resprays if the colour match is imperfect, & pinstripes/coachlines were also common & potentially useful too. Don't think there's any need to go too extreme anymore for these to stand out.
Last Edit: Mar 19, 2014 11:16:15 GMT by 79cord
Mar 19, 2014 11:32:47 GMT
As you say matt black would be wrong, though it was still common for these to be offered in '80's two tones divided at the upper door crease, such as Brown over gold. Dark grey or Blue over silver etc. which could work well. Plenty of creases to disguise partial resprays if the colour match is imperfect, & pinstripes/coachlines were also common & potentially useful too. This is great advice. Where are the rusty bits?
Mar 19, 2014 13:37:07 GMT
Treat the rust to stop it getting any worse I think the op would like to know how to do that.
Mar 19, 2014 14:12:46 GMT
Rust can be a bit like an iceberg. What you see on the surface is only the tip. To stop it you'll need to take the paint back to clean metal and treat the rust with something like Dinitrol Converust RC900 or similar (From . They have a section on rust! Doing the two tone thing would be good once you've treated the rust though. Period perfect and if you can do it yourself, not so expensive. As will all car work, the effort put into the preparation will be the key to success.
Peugeot 307sw - Suzuki SV650S - MX5.
Mar 19, 2014 14:30:48 GMT
Thanks for the input guys, surprisingly the bottom half of the car is in good condition with only a couple of scabs on a corner of the front valance, worst bits are, big scab in the middle of the bonnet, rust starting along all the passenger side of the bonnet, seam at the bottom of the rear screen, each corner of the rear screen, bit between the gutter and where the roof comes back up. As wagoneer says you have to take it right back to good metal, as ive found that kurust etc and a bit of paint arent enough to stop it coming back, thinking about trying to get the best paint match in a rattle can, sanding back the rust treat and fill and paint. As for mods, with it being a 1 owner 25000 mile car the only thing i will be doing is putting on a set of celica supra wheels on it, for now.
Mar 19, 2014 21:04:39 GMT
Rust is a pain to deal with just sell car to me
Porsche
West Midlands
Kev from B'ham.
Mar 19, 2014 21:42:17 GMT
Sticker Bomb it....no, don't I'm only joking. What about clear laquer, until you can afford a respray?
Mar 19, 2014 21:53:00 GMT
I'd say that depends on where and how bad it's rusting Got any detailed pictures? But no, don`t go matt black. Matt brown is much cooler
Mar 19, 2014 21:57:00 GMT
ill get some up tomorrow, it doesnt bother me about how it looks i just don't want it getting worse.
taurus
Mar 19, 2014 22:18:25 GMT
I second the Dinitrol Converust treatment. Kurust is a waste of time. On small bits like that I use a dremel to get back to clean metal, treat with Converust, then use a filler to fill any pitting, then I use an airbrush to touch in. You can get a really fine spray which makes an acceptable touch up. You'll need to do a bit of cutting back and it won't be totally invisible, but it's certainly way better than rattle can painting.
fred
WTF has happened to all the Vennies?
Rust and repair isnt such a scary thing, Looking at your pick I can see the edges of the bonnet need a fettle like many above have said, treat it. body work is 99% prep which to me is kinda therapeutic get rid of the rust, sand it all down to bare good metal, if it needs welding,(WCS) and your nay too good, get a mobile welder in, he will get it to filler standard. and gods lordy sake don't Matt black it! looks peachy as it is
Last Edit: Mar 20, 2014 7:52:26 GMT by fred
'79 Cossie ran Cortina - Sold
2000 Fozzer 2.0 turbo snow beast
'85 Opel Manta GSI - Sold
03 A class Mercedes
Looking for a FD Ventora - Anyone?
fred
. Matt brown is much cooler Matt brown? Never seen a Matt brown motor, Dairy Milk, or Galaxy ?
03 A class Mercedes
Bolf
Cheap paintjobs don't have to be traveller This one cost me £70 , DIY in my yard.
Mar 20, 2014 18:37:49 GMT
hamps
www.medwayrscentre.co.uk
Mar 20, 2014 19:51:16 GMT
Treat the areas properly, then just save and get them done, it will be so worth it
30psi
Mar 20, 2014 21:48:59 GMT
Some of the rust on my 910's are similar to yours. You have one disadvantage with the saloons, where you have the chome panel of the A pillars. The rust behind them can be awful.
1962 Ford Thunderbird 6.4L
1981 Datsun Bluebird SSS CA18DET
1981 Datsun Bluebird SSS SR20DE
