Fungus
Hi,
I just did a full service on the mk2f polo a mate has bought. It's a 1.3 with 82k on the clock.
The previous owner had been topping up the oil with wilko's mineral oil (what a clever chap) and it has no service history. It was still on it's original cambelt which was worrying.
I took off the rocker cover and was amazed at the amount of black sludgy-gunk that was pretty much everywhere. I cleaned off what I could from the inside of the rocker cover and put it all back on, so for now it's just got nice fresh oil and a new filter but still a lot of sludge.
What can I do about this? I've thought about a wash out with a paraffin gun and an immediate oil and filter change, as most types of engine flush are basically paraffin as far as I know.
Any ideas? The engine runs pretty well and doesn't had any bottom-end noise so it's definatly worth saving.
Thanks
Run some cheap, budget semi synth oil through it. A few hundred miles, oil/filter change. Repeat.
I did this with my Golf and it's great. I didn't want to flush it so went down the cheap oil, frequent change route.
Run some cheap, budget semi synth oil through it. A few hundred miles, oil/filter change. Repeat. I did this with my Golf and it's great. I didn't want to flush it so went down the cheap oil, frequent change route. This ^^^ but TBH ten miles is enough, I tend to do this when I buy a new car/engine. You will surprised how black the 'new' oil will come out after 10 miles!
Vauxhall Nova Estate Vauxhall Carlton V8
93fxdl
Enter your message here...
Mar 15, 2014 12:01:24 GMT
If you use an oil suitable for diesels they have a higher detergent loading, so will clean more than ordinary petrol specification oil Ttfn Glenn
taurus
Mar 15, 2014 17:32:43 GMT
I agree with all of the above!
Much better than using a flush. A flush can do more harm than good if it dislodges too much at once. You can get blocked oilways that way. Do a few changes with cheap diesel - extend the intervals gradually, and it'll be as good as you can get.
Mar 15, 2014 20:58:04 GMT
I think i would be tempted to drop the sump for peace of mind, just to make sure oil pump strainer not sh#tted up, and clean out sump.
Mar 15, 2014 22:44:01 GMT
I use a cheapy Adsa (or other brand) oil as flushes, run car for 10 miles or 15 minutes on mid range revs if not road worthy with a new filter then put in a mid range oil for the next 500 miles checking regularly before using the correct manufactures recommended grade with the correct oil filter, don't scrimp on the filter used.
Mar 15, 2014 23:19:16 GMT
Don't stick diesel oil in a filthy engine like this - the detergent will lift the dirt and carry it into places it shouldn't be in. Better to use petrol engine oil, even if it takes longer.
Mar 16, 2014 11:02:33 GMT
If its due a cambelt anyway whip the head off and stick it in a bucket of petrol then scrub off with a stiff brush. I can do a headgasket on the 8v's in half hour and the parts are probably cheaper than a load of oil.
Fungus
Mar 16, 2014 21:58:33 GMT
Thanks for the input everyone, lots of useful knowledge! It seems that it's something that will usually have to be done over a long period of time.. However, this; If its due a cambelt anyway whip the head off and stick it in a bucket of petrol then scrub off with a stiff brush. I can do a headgasket on the 8v's in half hour and the parts are probably cheaper than a load of oil. makes a lot of sense as it's such an easy job, and the cam and exhaust manifold are due to be replaced soon anyway! With Euro's current sale a full headgasket change comes to a whopping £24 so i think i'll be doing it next weekend. Thanks again everyone.
Mar 26, 2014 19:07:56 GMT
Take the sump off and clean the pick up pipe. If it's been sludged up, the likelihood is the pick up with have a few holes left to suck oil and it'llprobably be a bit tappety due to top end damage. I have done the petrol clean thing, but make sure the breathers are off before starting the car. (Can't link pics through Flickr anymore due to them 'upgrading' the interface) Clean: flic.kr/p/iSzcv9Blocked: flic.kr/p/iSxmrhBlocked pipe killed my engine (bottom end damage).
melle
South West
It'll come out in the wash.
Mar 29, 2014 11:44:10 GMT
(Can't link pics through Flickr anymore due to them 'upgrading' the interface You can for your own images: 'you' > 'photostream' > 'edit' > right click on desired thumbnail > copy image location > paste to forum > change the last 'm' (medium size) to a 'b' (big). Sounds more complicated than it really is, but it is the fastest way and leaves you without extra Flickr URLs under the image.
