93fxdl
Enter your message here...
Feb 16, 2014 21:40:39 GMT
Just partially seized my small compressor, got it freed off and replaced the black sludge with some 10/40. Runs fine now but is this a bit thin, should I refill with 20/50 or splash on some compressor oil or just leave the 10/40? Ttfn Glenn
sparkyt
selling stuff
Feb 16, 2014 22:17:04 GMT
Any oil ... It's not going to get hot enough to worry ..
My comp has been running on what ever I have to hand for the last 9 years its been fine .
93fxdl
Feb 17, 2014 15:15:27 GMT
Thanks for that, was just unsure as the sludge was really thick and have worked on some big compressors which ran really thick oil, serves me right for forgetting to service it, only 18 years ! Ttfn Glenn
Feb 17, 2014 23:15:18 GMT
93fxdl
Feb 18, 2014 16:35:30 GMT
Thanks, there's a toolstation near but I will stick with engine oil as I have a 20 litre drum and per litre its half the price Ttfn Glenn
Feb 19, 2014 22:22:59 GMT
As I understand it should be a monograde & some are synthetic. Which reminds me that mine needs an oil change after 4-5 years!
93fxdl
Feb 20, 2014 19:20:23 GMT
Finally got my Google head on, and did some research, now its clear as mud. Seems the usual is nd 30 meaning non detergent 30 grade but often Mobil 1 is listed as an alternative. It seems the reason for non detergent is to let the sludge settle and not be carried in the oil. Something to do with the sludge making the valves sticky, but presumably the Mobil 1 being synthetic dosent cause this problem. Since my aching head cannot stand anymore confusion, I will stick with the 10/40 which is semi synth so should be semi ok, but change it a bit more often, like every year not 20 years. seems the correct oil is best but ordinary engine oil is only just second. Plus if the compressor does go phut there's no shame in it, and will give my an excuse to upgrade. Ttfn Glenn
Feb 20, 2014 19:24:36 GMT
Hi, if it say's no detergent oil, then don't use a diesel engine oil.
Colin
93fxdl
Feb 20, 2014 21:32:31 GMT
The reasons my head is spinning are, they say use non detergent 30 oil or Mobil 1, which is a multigrade detergent oil Ttfn Glenn
rxv8
Feb 20, 2014 22:06:11 GMT
