Feb 16, 2014 17:00:30 GMT
Hey, Has anyone replaced a abs sensor on a audi a4? On the old sensor the cable had snapped so I have replaced the sensor but the abs light is still on and, although I haven't tested to see if the wheels lock up, I'm assuming the abs wont work... any ideas/ help? Rich
Rich
Club RR Member Number: 160
2000 Audi abs issuesRich
@foxmcintyre
Club Retro Rides Member 160
Feb 16, 2014 18:50:17 GMT
You need a code reader. It has OBD features, make use of them Might just need to code clearing.
Feb 16, 2014 19:24:48 GMT
Ive had hooked up to a small Blue Point one and it didnt come up with any codes, think I may have to get it on a proper one scanner
Feb 16, 2014 19:36:13 GMT
Have you driven it down the road
Feb 16, 2014 21:22:13 GMT
Those obd codes readers only read engine codes
Yeah, I've driven it about half a mile
2000 Audi abs issuesChasR
@chasr
Club Retro Rides Member 170
I'd be looking to find someone with VAG-COM and the relevant interface for it to work with your car. It should pinpoint down what else is the issue. Alternatively you could go around checking the resistance of the remaining sensors on the car.
Feb 18, 2014 19:41:01 GMT
ive got vag-com but the cable doesnt work with the audi... it works on mk4 golfs and seats!
zx9
Kinda New
Feb 18, 2014 20:36:31 GMT
ive got vag-com but the cable doesnt work with the audi... it works on mk4 golfs and seats! The VCDS cable works perfectly with my B5 A4, if you have a genuine cable you need to ask Ross Tec whats up, if it is an Eblag £12 quid job, who knows.
Feb 18, 2014 22:32:51 GMT
its a ebay one, I think its cos the audi is canbus and the other stuff ive used wasnt canbus. I should be getting it on a proper scanner tomorrow
@chasr
Feb 21, 2014 23:44:02 GMT
A HEX-CAN cable will definitely work according to Ross Tech. Cheap however it is not!
Saying that, it was worth the cash on my Pissat with the errors it was causing and in diagnosing issues.
