Carter
Needs boring out from standard 85mm to 86.8... So to 87mm and probably have to use oversize Pistons from a 280z/L28 engine, as I can't afford custom forged. Hopefully compression won't be too high, research is underway. So, apart from new pistons it needs big end bearings, main bearings, new water pump, new oil pump, full gasket set, chain tensioner pad, and cam chain guides. Will need bottom end balance, maybe a head skim etc. Also, the distributor may need replacing, and the electronic ignition will need replacing soonish!
'77 Chevy G20
Apr 12, 2015 21:47:08 GMT
If it helps in anyway, I'm happy to give a full refund on the engine if you return it, (i'm not buying any more engines from Australia!) Bearings etc should be cheap to find , and I probably have a cam tensioner pad, but the guides may be unique to L20 and have to come from the States . Imagine how well that would go if it was breathed on a bit, bored out, camshaft etc.
Ive got some L28 pistons if you need some dude
Play'in round with an old Datsun & a Ford COE
Shame about the engine letting go, but as said, time for bigger and better high comp cammed up weber snarling beast;)
Nobody dies a virgin, because lifes curse word us ALL
Carter
Apr 13, 2015 16:40:18 GMT
If it helps in anyway, I'm happy to give a full refund on the engine if you return it, (i'm not buying any more engines from Australia!) Bearings etc should be cheap to find , and I probably have a cam tensioner pad, but the guides may be unique to L20 and have to come from the States . Imagine how well that would go if it was breathed on a bit, bored out, camshaft etc. No, I'll stick with it as I'm too far down the line with it now, what with the 5spd conversion, prop shaft shortening, and manifold/carb job. Thanks for the offer though! Going to bore out to 87mm and use early 280z 0.040 oversize pistons.
'77 Chevy G20
Carter
Apr 13, 2015 16:45:52 GMT
Ive got some L28 pistons if you need some dude Thanks for the offer, but I need oversized L28 Pistons. It'll all come good, ball is rolling, hopefully will get it sorted for Retro Kings/RR thing at Snetterton. If not, well, summer is coming and I have a weekend RRG ticket.
'77 Chevy G20
Apr 17, 2015 20:16:34 GMT
If I can help in any way fella just let me know ?
Carter
Apr 17, 2015 23:05:49 GMT
If I can help in any way fella just let me know ? Thanks Dom, it's all pretty much in hand at the moment.
'77 Chevy G20
Carter
Apr 18, 2015 12:21:23 GMT
Same as Dom, if you need a hand shout Thanks, appreciated!
'77 Chevy G20
stuey
ram thruster 4000
May 20, 2015 16:35:42 GMT
Nice to see you back in the fold- I still have photos of your sapporo when it was painted- lovely car that- Ill try and check your truck out at snetterton if you make it along- it looks awesome!
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
Carter
May 20, 2015 22:24:33 GMT
Nice to see you back in the fold- I still have photos of your sapporo when it was painted- lovely car that- Ill try and check your truck out at snetterton if you make it along- it looks awesome! Hey man, how's it going? The Sapporo... I still miss that car. Be great to catch up either way!
'77 Chevy G20
Carter
May 20, 2015 22:53:34 GMT
Boring out, skimming, balancing etc done. Oversized 280z pistons fitted to the con rods, and all parts good to go. Spent some time today cleaning the block, with a lick of paint, while my man prepped for putting it back together. Obviously the machined faces will be cleaned of paint... Cleaned up the rocker cover too.. I stripped and shot some VHT paint over the exhaust manifold too... Bad photo The workshop is closed up for a long weekend due to a trip to Pendine, hopefully get back on it next week and get finished for Retro Kings, maybe.
'77 Chevy G20
excellent !!Glad to see you are cracking on with it. Be good to see it at Retro Kings
Carter
May 21, 2015 15:28:09 GMT
'77 Chevy G20
May 21, 2015 22:58:50 GMT
Looks like a Ferguson Tractor engine now Hopefully a lot faster though.
May 22, 2015 16:11:52 GMT
Nice work.
Carter
May 27, 2015 19:35:25 GMT
'77 Chevy G20
bstardchild
Club RR Member Number: 71
'71 Datsun 521 pick-upbstardchild
@bstardchild
Club Retro Rides Member 71
May 27, 2015 20:10:07 GMT
Oooooh - looking very nice and coming together hopefully in time for the weekend
