benzine
Club RR Member Number: 87
I have an OM602 that I'm putting in a project. It was going to be automatic but now I have the option of making it manual. Which gearboxes will bolt straight on with minimal fuss? Will gearboxes from an E class with an OM605 bolt straight on? Sprinters? (even later 6 speed boxes?)
Thanks for any info
sowen
Club RR Member Number: 24
I bought my first OM605 from a C250td and that had a manual box. The Sprinter gearboxes on Ebay appear to have the same bellhousing pattern as the earlier OM60x series of engines. I think the later saloon cdi engines also shared the same bellhousing pattern going by the Ebay pics.
benzine
Thanks, I've looked at a few manual boxes on ebay and many seem to have the same bell house pattern. I've not seen gear linkages like these before though: I'm trying to find pictures of the gearstick end of the arrangement
sowen
To be honest the rods confuse me too, I ended up cutting off the first 2" of the bellhousing flange and welded it onto a Land Rover bellhousing, that now sits quite happily in my Land Rover and seems to work well. An alternative I've just stumbled on would be a T5 gearbox, and the bellhousing from a Ssangyong Musso... The Ssangyong T5 has a different tail housing from normal rwd T5 boxes, and is an alternative that could be used if you can find the bits?
benzine
Ahh that's interesting. Is that an LT77 box in your land rover? I have one in my kit car and I extended the gearstick linkage myself so I'm familiar with that already. I had a manual box from a musso but sold it as the plan was to go auto, doh!
sowen
Doh indeed! Yes, the Land Rover is LT77, I've put a few photos up of how I stuck it all together in my Land Rover build thread. There are a couple of other options I'm exploring for easier manual gearboxes to use and fit, but not actually made anything yet.
benzine
Ahh yes I see, great project! I'm quite a fan of the LT77, easy to change the gearstick position and cheap to buy so I'll bear it in mind when choosing a box
sowen
Ahh yes I see, great project! I'm quite a fan of the LT77, easy to change the gearstick position and cheap to buy so I'll bear it in mind when choosing a box Yep, nice gearboxes, shame about the reputation people give them for running them on ATF! I'm building an adapter to take an OM60x onto the rwd R380 gearbox, I'm sure some people will take great offence in that but it's a decent heavy duty proven gearbox, cheap and I have a small collection of them to destroy!
hario
S202 C300STD
Feb 19, 2016 20:29:11 GMT
To be honest the rods confuse me too, I ended up cutting off the first 2" of the bellhousing flange and welded it onto a Land Rover bellhousing, that now sits quite happily in my Land Rover and seems to work well. An alternative I've just stumbled on would be a T5 gearbox, and the bellhousing from a Ssangyong Musso... The Ssangyong T5 has a different tail housing from normal rwd T5 boxes, and is an alternative that could be used if you can find the bits? May I ask, the Ssangyong T5 is a manual 4x4 gearbox with an OM603/606 bell housing? If it is would you mind telling me which side of the gearbox the front drive transfer case is on? Beers, H
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
sowen
Feb 20, 2016 14:25:19 GMT
To be honest the rods confuse me too, I ended up cutting off the first 2" of the bellhousing flange and welded it onto a Land Rover bellhousing, that now sits quite happily in my Land Rover and seems to work well. An alternative I've just stumbled on would be a T5 gearbox, and the bellhousing from a Ssangyong Musso... The Ssangyong T5 has a different tail housing from normal rwd T5 boxes, and is an alternative that could be used if you can find the bits? May I ask, the Ssangyong T5 is a manual 4x4 gearbox with an OM603/606 bell housing? If it is would you mind telling me which side of the gearbox the front drive transfer case is on? Beers, H Sorry I don't know for sure, I bought the gearbox minus the transfer box and Google images indicate the front drive goes along the left side?
