SIP migmate 130 TURBO. I bought this new quite a while back restored a couple of minis with it then upgraded. Has New tip shroud and liner fitted, 4 spare tips, a spot weld shroud,a couple of liners a full disposable co2 and a 5kg roll of 0.6mm wire with about a kilo left on it. Currently can't find the bits to hold little cylinder on back. Has had the wire feed stregthening mod done. Sale was on hold as my big welder packed up but managed to fix it using the power relay from this so now has a brand new power relay fitted and all in GWO again £40 ono Collected BMW 1.8 cam locking plate £8 (to cover postage) Renault locking kit (1.8/2.0 16v model) may do others £18 delivered Genuine renault aux belt kit, suits renault scenic with aircon may fit others £25 delivered BMW E46 genuine inner track rod as new never fitted £20 delivered VW random pair of bearings, pretty sure they suit T25 aircooled and are for the gearbox main shaft. £40 delivered Set of brake shoes for cars listed £15 delivered Set of 4x114 15" banded steels, banded by Dez, staggered fitment 7" fronts 8.5" rears (originally 6" with a 40 offset) paint is crazed ideally needs redoing, i started on one of the rears and had a play with colours. The front have a pair of admiral 195/55r15's fitted. PROVISIONALLY SOLD Sunroof (from the s12) 75x38cm cut out. Glass can be removed. Would benefit from a clean and a new bit of trim where fixing screws go (not essential) £20? S12 bits Passenger foot rest £20 wash wipe headlights (inc switch) with stone protectors £50 Bootlid, good condition, no spoiler, little bit of surface rust and some holes drilled along top to mount the roof rack. Window trim is lifting off on one side £40 Bonnet good condition £20 Doors need bit of work to make good £10 ea Windscreen, come and remove it and it is yours. Pair of struts unmodified with used discs, pads and calipers (also have a spare pair of 40-54mm conversion spacers to fit most datsuns) no springs, can convert to adjustable coilovers/section them down if parts are provided/paid for in advance. £65 as is
Last Edit: May 30, 2014 20:18:53 GMT by damien4884
1977 datsun 810 180b estate
turbom
£30 for the fibreglass cloth??
Paypal??
mud
£50 for the mig?
Cheers Mud
Fair bit of interest in the MIG i'll try and get it dug out today and giving it a test run check over.
Few more bits added to first post!
intereted in the mig damien
"Understeer" is when you hit the fence with the front of the car.
"Oversteer" is when you hit the fence with the rear of the car.
"Horsepower" is how fast you hit the fence.
"Torque" is how far you take the fence with you
peddyp
Feb 13, 2014 22:56:34 GMT
May well be interested in the washer... Will keep you posted!
Feb 14, 2014 18:02:39 GMT
Just for you price drop on the parts washer and I've now got enough packaging to wrap it for courier if needed
How much would the courier be for the parts washer? Thanks
Feb 16, 2014 11:24:26 GMT
I can send it out on 48hr service for £15 (ime it turns up next day 90% of the time)
Feb 16, 2014 12:07:20 GMT
Next in line for the parts washer please! :-)
Koos
Feb 16, 2014 23:35:44 GMT
I can send it out on 48hr service for £15 (ime it turns up next day 90% of the time) Right will have it, got to come in useful at somepoint, is paypal ok? can you pm me the total and your email address please. Thanks Giles
🇿🇼Kingludba🇬🇧
If in doubt... flat out !
Where you moving to bud?
`99 BMW 528i auto - current `01 Merc C320 - Gone `01 Forester S-Turbo - Sold `89 BMW 320i Convertible - Sold(shoulda kept it ) `88 Toyota MR2 T-Bar - Sold `89 BMW 325i touring - Sold `89 BMW 535i - Let her go too early `85 BMW 320i 2 door - Rust = character `00 Subaru Impreza Turbo wagon - Sold (engine failure) `93 BMW 325i - Sold
Don't know yet, will still be around here. I've not got long to make the place look presentable before it goes on the market.
adamb
Feb 17, 2014 17:46:52 GMT
Can you reply to my pm's? I offered to collect. I've been waiting since Friday for a reply, pm me your number please!
adamb
Feb 17, 2014 17:47:03 GMT
adamb
Feb 17, 2014 17:47:17 GMT
povey
Feb 17, 2014 18:12:17 GMT
Is the mig welder still for sale?
Feb 17, 2014 18:48:43 GMT
The mig welder is still here but only because I've not had the time to dig it out and test it. There is a fair list of people who want it and I`'ll be going through them in order of who asked first to see if they want it still.
🇿🇼Kingludba🇬🇧
Feb 17, 2014 23:23:10 GMT
Don't know yet, will still be around here. I've not got long to make the place look presentable before it goes on the market. Good luck with the sale chap.
Feb 21, 2014 15:00:43 GMT
Can I take the coil pack please.
Last Edit: Feb 21, 2014 15:02:18 GMT by spongeh: injectors are DET and I have ET
1987 Reliant Scimitar SS1 1800Ti - The turbo one / '92 Hymer B534 / '98 Suzuki TL1000R
spongehuk.wordpress.com/ - My blog on all my toys
