Volkswagen Polo 1.6 CL Open Air
112k
Part History
Five Speed Petrol
Five Door
Metallic Black (just washed in pictures)
Tax runs out 31/1
MOT until August 2014
Electric front windows
Electric Full length Webasto style sunroof
Car drives spot on and is sporty (100bhp engine) economical and cheap to insure.
Interior is in very good condtion and even has the original factory car mats fitted!
Has aftermarked CD Player fitted
Car is in good overall condtion bearing in mind its age. Drives spot on.
I acquired this car recently as it had been standing for about six months, hardly used since I bought it (short runs only) however now tax is nearly out I'm selling as it is surplus to requirements.
As you will appreciate it is an old Polo and does come with a few faults, there is a rust patch to the bottom side of the drivers door. Two rust patches on the rear valance. Theses rust patches in my opinion could be done quite easily.
The gear knob (bit that you touch) has been repaired, the bit that shows you the gears on came off and has been re glued in place. has no detrimental effect whatsoever.
Crack to very bottom part of the windscreen, out of the field of vision.
Finally the ignition, if you turn the key normally to start - It may! However if you turn the key and wiggle it slightly it will Start. Common issue apparently and a check for a loose wire r even a £12 ignition barrel will solve this. Once you get used to this it really is not an issue.
Non Smokers car
Any questions please just ask. PM with email for pictures (unless I work out how to do them in the meantime)
