hi folks here is my fiesta mk2 pop project looking to maybe swap i'm looking for a mk3 capri or other 80's ford or something rwd
or sell. car is not running , needs some work, will be an animal when done lost interest again lol
car needs
fuel tank repairing its a mk2 diesel tank with swirl pot , fuel pump fitting , wiring loom for ecu made up have diagram
and loom made from donner car loom crude but should do to start
o.s sill needs fitted + 2 small plates in engine bay
mounts for intercooler need to be make just tabs welded to front panel
oil drain needs drilled and taped
engine mount finished needs tab welded for third bolt
ecu will need to be mapped
exhaust downpipe is diy to clear crossmember may not be to some people's standard i planed to remake in bigger bore pipe
fitted to car
rs1800 zetec engine
rst t3 turbo with -31 actuator+ aapter plate
lsd gearbox
leda race spec suspension
adjustable panhard rod
poly bushed
90 spec front seats xr2 rear
front mount intercooler wit alloy pipes
momo steering wheel and boss
xr2 clocks in pop dash needs smoothed off
parts not fitted
xr2 pedal box
spare hubs + shafts
rollcage from race car
gizzmo ms ibc electronic boost controller
aem wideband gauge and sensor
megasquirt1 extra v3.0 with pigtail loom + edis4
spare doors, bonnet, tailgate
o.s sill
fuel pump
tank with swirl pot (needs work)
decompression plate
rs1800 ecu
parts needed to finish
oil feed line
uprated fuel presure reg
scooby turbo injectors
brakes as only has 1.0l brakes
exhaust
best to come have a look as prob forgot loads
car needs
fitted to car
rs1800 zetec engine
lsd gearbox
poly bushed
parts not fitted
xr2 pedal box
spare hubs + shafts
o.s sill
fuel pump
decompression plate
rs1800 ecu
oil feed line
exhaust
