Hi all, I have an LT77 gearbox and bellhousing out of an LDV Pilot van for sale, complete with gearbox mounts/cradles each side, suitable for converting a XUD diesel/turbo engine etc. to RWD. Includes the shifter/remote mechanism and LDV gearlever. I've got a used clutch throw arm, and another brand new in box, plus I think I've got the hydraulic release bearing (have to check). I've also got a Peugeot 306 HDi flywheel so you can run a bigger/stronger 228mm clutch and enables the use of a PUSH type clutch (the XUD clutch is pull and not suitable).
You'd need an LDV spigot bearing (few quid), a suitable clutch to fit the flywheel (about £100), and a slave cylinder suitable to match your master setup (£20-40), and you've got a full turbo-diesel ready RWD set up! (Will check if I've got the release bearing).
Bought this a couple of years ago for a project but I won't be using it anytime soon so just trying to recoup my costs, £200ono.
Pics on request.
Pics on request.
