Ok, it's the time again, I need to clear some space as 11 cars is about 6 too many and since getting the Storia I've not used the rally car.
Model: Daihatsu Cuore Avanzato TRXX-R4
Year: 1998
Mileage: 11k rally car
Tax: None
MOT: 12 months when sold
Price: £2200 for both cars and lots of spares
Contact details: PM or post here
This is one of the original challenge series rally cars prepared by Harry Hockly. It is a tad scruffy, but it is a used rally car, which to me adds character. It has 11k miles on the clock and comes with loads of spares, and a total of 3 sets of the custom made rally wheels (4x 110 pcd). It currently doesn't have T&T, but if there is serious interest I will put 12 months MOT on it for the price stated. It's done probably 200 miles since it was last MOT'd and is regularly started and moved, so the brakes don't stick etc. I expect it to pass an MOT without issue.
For those that aren't aware of the challenge series cars they took a standard 659cc turbo, 4wd road going avanzato and gave it to harry Hockly to prepare for a one make series. They were completely stripped out, have FIA spec roll cages, plumbed in fire extinguishers, kill switch. The fuel and brake lines run through the inside of the car. There is a very substantial sump guard at the front and a heavy guard over the fuel tank at the back of the car so very little underneath is exposed. The springs and shocks were custom made and are incredibly firm. The ecu was also modified and has a rev limit somewhere around 10k rpm. This one also has a stage timer fitted. There is also a custom made stainless steel exhaust from the cat back fitted that has only done about 1000 miles.
s87.photobucket.com/user/skattrd/library/Trackday/Cadwell_3_8_2010
s87.photobucket.com/user/skattrd/library/Rally%20Sneeze
The road car mentioned here is externally scruffy, most panels are dented or scratched and it has been unused for approx 2 years It has 47k on the clock. When it was last used the aircon, electric mirrors, windows etc all worked. It did have a couple of issues though, fuel gauge not working, rear diff leaked a bit of oil and there is no prop-shaft fitted. I used it for 6 months or so like this, topped up the diff when needed and the car ran fine in 2wd without the prop-shaft. I do have a spare fuel tank, rear axle and prop-shaft with the rally spares. I have also acquired a matching JDM rear light so they match.
s87.photobucket.com/user/skattrd/library/Zato
Spares:
2x spare sets of rally wheels 1x Yoko Advan track tyres, 1x loose surface tyres, the ones on the car have road tyres fitted
1x Front bumper
1x Front subframe
2x quarter panels (new)
4x doors
1x tailgate
3x bonnets
1x fuel tank guard
1x engine block - holed (dismantled may not be complete)
1x prop-shaft
4x drive-shafts
1x gearbox (dismantled may not be complete)
3x springs
3x shocks
1x steering rack
1x rear axle (complete)
1x light pod
1x clutch
+ other bits and pieces, lights, electric bits, suspension parts, cables.
Price
Rally car & lots of spares £1800
Rally car + road car & lots of spares £2200
Road car (which has been off the road and unused for 2 years) with replacement prop-shaft & rear axle £500
These prices are the absolute lowest I will take, so no haggling or offers
Year: 1998
Tax: None
Spares:
1x Front bumper
1x Front subframe
4x doors
1x tailgate
3x bonnets
1x fuel tank guard
1x prop-shaft
4x drive-shafts
3x springs
3x shocks
1x steering rack
1x light pod
1x clutch
Price
