tom13
Hi guys, Iknow this has been done over and over but I want to cut the springs on my micra asap but i need to know the process. Will i need any additional parts? From what i have seen on other models its just a case of taking off the desired coils and then fastening the spring to the top mount or lower? Presumably wiyh juiblee clips?
I can get the shocks off easily but its the cutting part. Anybody have any idea how many i should take off to get it low but useable? I am thinking two?
Cheers
Tom
Take it form someone who knows what he is talking about don't DO IT AT ALL....Save your money and buy some proper ones that are lowered they ARE available
Dave
bl1300
If you want it to handle as it was designed afterwards you will need shortened shocks as well. If your just cutting the springs you will also need to shorten the bump stops. Personally id fit a proper lowering kit to it.
Current fleet.
kevfromwales
the conrod's REALLY out the block now!
Jan 10, 2014 17:27:08 GMT
oh god, here we go again..
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Foxy
Making pink manly in the north!
Jan 10, 2014 17:35:48 GMT
Get a grinder out. What's the worse that can happen. done it to nearly every car I've owned and guess what. Mot man.....happy. nuns and kittens......still alive and I'm not ccurrently sending this message from heaven nor a ditch in Lincolnshire. Do it properly and everything will be okay. Do it like a dickend and well, maybe not so much.
I'm the handsome fella with the cheesy white specs or is that the cheesy fella with the handsome white specs?
Jan 10, 2014 17:37:55 GMT
Just make sure you cut the coils from the correct end: K10 springs are pigtailed at one end, and parallel at the other. You want to be chopping the parallel end. Don't you, rtlkyuubi?
Last Edit: Jan 10, 2014 17:38:13 GMT by jrevillug
smellyferret
Back in a retro after 7 years!
Jan 10, 2014 17:51:42 GMT
Cutting micra k10 springsstealthstylz
@stealthstylz
Club Retro Rides Member 174
Jan 10, 2014 17:52:39 GMT
Jack car up, turn wheel to full lock, select the most accessibile coil (usually means chopping off 2 at a minimum, but you were gonna do that many at least anyway right? Don't be pussying out doing one, that's as bad as -30mm springs), fire up the grinder with a skinny disk in and start chopping through the spring. Once you've got a decent notch in it hide your face behind the wheel and with an outstretched arm chop through the rest. Wait for the bang. Sweep up remains of cutting disk and fit a new (used is best) disc. Chop the bit of spring you've chopped off into half circle sections to remove. Drop car off jack. Do the other corners same. Jobbed.
grumpy
Jan 10, 2014 18:04:31 GMT
Bodger.
kevfromwales
Jan 10, 2014 18:05:56 GMT
remember that white k10 from the retro show that was on it's ass, then we all stuck our heads underneath and it had NO springs at all?
LOLOL
Cutting micra k10 springsRobinxr4i
@robinxr4i
Club Retro Rides Member 143
Jan 10, 2014 18:15:08 GMT
I recently cut the springs on my own K10, nothing special to be concerned with the fronts will ideally require a spring compressor to be safe. And as Vilerug said cut the non-pigtail end (although I can't remember if they are actually pig tail on the Mirca). The rear is diabolically easy as the springs aren't even under tension with the rear jacked up.
I removed one coil front and back which gave a modest drop 20mm something like that. Ideally you'll want to wire/cables is the springs into the cups to avoid dislocation.
Just to add to the debate about cut springs....
I've personally owned cars lowered with proper lowering springs, coilovers and cut springs. IMHO they can all be "dangerous" however they can all be "safe" too, the important thing is to take your time, think and learn from experience. Start small if you aren't confident you can always remove more later.
Last Edit: Jan 11, 2014 9:21:08 GMT by Robinxr4i
sparkyt
selling stuff
Jan 10, 2014 18:21:33 GMT
I don't think I've every had a car that Ive not cut the springs on ..
I undo the top nut jack the car up the weight will come off the spring just keep jacking
Then when you cut it shouldn't kick
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
Cutting micra k10 springsspeedy88
@speedy88
Club Retro Rides Member 118
Jan 10, 2014 19:11:13 GMT
Both my cars and most of my past ones run cut springs, they're perfectly fine.
Jan 10, 2014 23:11:17 GMT
Do it properly and everything will be okay. Do it like a dickend and well, maybe not so much. And knowing the difference is a big issue with some.
Last Edit: Jan 10, 2014 23:14:47 GMT by Deleted
