jonomisfit
Club RR Member Number: 49
1996 mx5 1.6 monza in green for spares or repairs. I bought this as a donor for my hotrod, but ended up buying a load of bits from a local crashed one instead. I used it for a few months until the MoT ran out in June. Took it for a new MOT and it has all of the normal mx5 issues of rust (19 different points i think on the advisory). Not got the time or inclination to fix it. The roof is in fairly good condition with no tears / holes / cracked plastic etc. Has coilover suspension fitted (no idea what type, cheapish maybe raceland?)one top mount of which has a double nut on it. One of the wishbones has a hole cut in it to get to the suspension bolt. There's a fairly good second hand wing with it to replace the drivers side one that has a hole in it. An extra set of alloy wheels with tyres, i think they're quite nice looking, with a bit of dish to them. It was running (when i last drove it) but the battery has now died. I'm not inclined to replace it but it started from a jump earlier. I'm Looking for £450 with the extra set of wheels. Car located near Ulverston in Cumbria. Please PM all i'll send you my number.
Last Edit: Jan 14, 2014 20:54:27 GMT by jonomisfit
jonomisfit
Its also had a parking bump on the rear, at least i'm guessing it is as its got the normal sort of bollard imprint in it.
And the carpet / trim missing from the boot is lying in my shed and will come with the car. The engine in the wheels pic doesnt....
Oh and it has a water leak in the boot which i'm pretty certain is from the areal.
jonomisfit
Dec 11, 2013 20:13:05 GMT
bump
Dec 11, 2013 21:40:40 GMT
could you post up a copy of the MOT sheet?
Cheers, James
jonomisfit
Dec 14, 2013 15:27:08 GMT
I've managed to loose my camera, but will post up later if I can find it.
List Goes:
1) Offside front track rod end ball dust cover insecure 2) Nearside front out rigger subframe mounting prescribed area is excessively corroded 3) Offside front out rigger subframe mounting prescribed area is excessively corroded 4) Nearside rear weld incomplete suspension component mounting prescribed area is inadequately repaired 5) Nearside rear weld incomplete suspension component mounting prescribed area is inadequately repaired 6) Nearside front chassis seatbelt anchorage prescribed area is excessively corroded 7) Offside front chassis seatbelt anchorage prescribed area is excessively corroded 8) Offside front upper wishbone pivot pin subframe corroded and seriously weakened 9) Exhaust emissions excessive after 2nd fast idele 10) n/s front mirror missing 11) o/s front engine mount corroded
jonomisfit
Dec 29, 2013 22:49:14 GMT
Bump.
Still cant find the camera, but the fail list is as above.
If there's no interest in a couple of weeks i'll be dismantling, keeping anything of use to me and scrapping the rest.
Jono
jonomisfit
Found the camera.. lying in a box in the garage. Not very good photo i'm afraid.
would you break it? some nice bits on it.
jonomisfit
I'm really looking to move it on altogether, but if it doesn't go soon i'll be breaking it.
What would you be after?
The windbreaker, possibly the coil overs and depending which one,the differential.
Jan 10, 2014 22:39:31 GMT
£250 any use to you? I would offer more but I've got 4 cars and 1 garage!
Thanks, Stuart.
I'm not wrong, you just don't agree with me. There's a difference!
jonomisfit
Jan 11, 2014 16:32:32 GMT
Fraid not Stuart. I'd get that selling the coil overs and wheels.
Good ole duke. Standard 1.6 diff.
Jan 13, 2014 20:23:46 GMT
Fraid not Stuart. I'd get that selling the coil overs and wheels. Good ole duke. Standard 1.6 diff. Offer's always there if you feel you need to get shot.
jonomisfit
Jan 13, 2014 20:51:26 GMT
Car is sold subject to payment and collection.
jonomisfit
Jan 14, 2014 20:54:36 GMT
SOLD
