I've always wanted compo ML's on the spider. what is the normal tyre width to fit on an 8" wide rim - as I want to stick 195/60/15 tyres back on.
71 Alfa GT 1300 Junior 89 Alfa 75 3.0 V6 Veloce 89 Alfa 75 3.0 V6 America 2015 C220 estate Daily shunter
bstardchild
Club RR Member Number: 71
what tyres to fit on these ?bstardchild
@bstardchild
Club Retro Rides Member 71
I've always wanted compo ML's on the spider. what is the normal tyre width to fit on an 8" wide rim - as I want to stick 195/60/15 tyres back on. Can't find me book but I reckon that would be a bit of a stretch
I would think that a 225 would be the ideal size on an 8, but that the 195s would look rather good!
I would think that a 225 would be the ideal size on an 8, but that the 195s would look rather good! Thats what i got on my 8 inchers.
195\45 looks goood, and is TÜV approved too If you get a tire with flat enough sidewall i should think it would look good aswell
145/60 + tubes
on my 16 inch pentas ive got 205s on the front, and the've got a little bit of stretch, and 225s on the back, which have got pretty much vertical side walls.
its a kind of unanamous decision that 175/50's look the best on an 8" wheel, bridgestone potenza or proxes have the best sidewall shape too with the 'right' sort of rim protector.
but these days ive turned to likening a FAT bit of tread, so 225/235's with as low profile as poss FTW
