Hi,
I have the following parts available for sale for e36.
All are available for up lift from either Glasgow or Edinburgh, or can be posted via Paisley Freight courier service.
Please have a look and if there’s anything you’re after drop me a message
Pair Bilstein B4 front dampers and springs £85 + Post
Look relatively new- no leaks, springs in good condition, as are topmounts. These are £230ish a pair new, with no springs/topmounts. The springs were ok on my 328-so think they are 6pot springs
Fits all non m3 e36
Part numbers are VNE-4419/20
Pair of Koni Adjustable front dampers £120 +post
In good condition- Adjusters work freely, and the damping is controlled and effective. I had them on the front of my 328 touring and the ride quality was great- a lot better than my brother’s ebay coilovers.
The lowering springs on them give a large drop- but of course you can swap them out. The bottom pic shows the rideheight on my 328 touring
Part number is B741- 1235Sport
Touring front lights £25 each inc indicators £20 each without indicators +post
In great condition- no broken clips and holders for indicators intact.
Lenses in good condition as are front covers, Bulb covers present and fit well
Available with or without the Indicators, and I’ll sell L/R separately as you may just need 1
E36 Saloon/Touring indicators £6+ post Each
Again, in good condition- all clips present. RH one has a couple of chips out the edge of the lens, but no cracking. See pic
Rear Lights (e36 Saloon/Touring/Compact) £10 each plus post
In good condition, with the 4x 8mm nuts present.
Bulb holders in good condition, all clips present.
Various e36 Air Con parts
Compressor + Bracket £35 + post
Seiko Seiki make, for R134a
Dryer £10 + post
Gen BMW in good condition with bolts and screws for pipe attachment and mounting to the car
Pipes from Bulkhead £10 each plus post
In good condition, insulation present and the valves work freely
Fits all non m3 e36
Dryer £10 + post
