Rover V8 Engine - for spares/repair.
Engine number: 10A21597
(Using the Rimmer Bros website the engine number decodes as a Rover SD1 V8 Manual. 9.35:1. 1976 - 1987.)
Was running in my Capri & removed 12 months ago. Has been dry stored in my garage since & turns over freely by hand. Removed from car as suspected worn crankshaft.
To confirm: There is no front cover/oil pump etc/carb/intake manifold/exhaust manifold/engine mounts as these were all transferred over to the new engine. It has a rearward sump suitable for a Capri fitting. It has a flywheel for a manual box.
I would suggest this is good for a rebuild for your kitcar/conversion, use in V8 Stockcars or to go back into an SD1.
Ebay: www.ebay.co.uk/itm/271323330299?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
Ebay ref: 271323330299
