Fresh out of the container today this 68-72 model Datsun 1300 pickup (521 series) all the way from Australia. Column change, bench seat. 1 Tonne pickup. Chassis is solid, needs work on cab. Good project.. have the only one in UK! Better pics etc in a few days. More of a heads-up at the mo as I wont get the customs documents to enable it to be registered for a while. But you can reserve it. SOLD
Last Edit: Feb 22, 2015 12:01:46 GMT by datman
Oct 26, 2013 13:54:26 GMT
very cool will, that wont hang about for long. glws
provisionally sold to Nick K (not Kershaw) I will have something else available in the next month or two so watch this space.
Nov 28, 2013 16:28:39 GMT
Just wondering if your bulletside was still kicking
which ones that?
Dec 12, 2013 10:07:48 GMT
Dec 12, 2013 14:07:45 GMT
May 27, 2014 12:57:43 GMT
This came over as just a chassis cab, but I sourced a rot-free original pickup bed for it in California and had that shipped over and it is now sat on the truck so it looks a bit better. www.datman.co.uk/e/521bris006.jpg/img]Here's a rundown on what we've done on this truck so far Fit battery. Wrong spark plugs . replace replace ign coil. remove/strip/clean clutch master cylinder remove/strip/clean brake master cylinder indicator repeater lenses missing, replace units replace IGN Switch clean inside of FUEL TANK rh front wheel cyl stuck and leaking strip/hone/grease/assemble lh front wheel cyl leaking, replace cyl rh rear wheel cyl sticky front piston. strip/hone/grease/assemble lh rear wheel cyl leaking strip/hone/replace seal, grease/assemble skim front brake drums. replace front shoes replace rear shoes replace handbrake cables unblock lh rear metal brake pipe. 1 f sidelamp not working, clean contacts, replace bulb Fill cooling system and test drive. Plan on this is to carry on the work to get roadworthy (needs tyres etc and floor welding) and get it MOTd and registered. Cost will go up accordingly. But if you want it as-is and do the rest of the work, give me a shout.
Last Edit: May 27, 2014 13:00:17 GMT by datman
Managed to scrape through an MOT. Is now UK registered. (Age related plate.. G reg)
Sale pending.
quackshot
...friggin' cars...
Hasn't this sold yet to Nick?
Going to a chap in Suffolk at the weekend (apparently) .
quackshot
...friggin' cars...
Keep me posted
Jan 11, 2015 16:33:53 GMT
okay Quackshot, despite the guy from Suffolk ringing on Friday to confirm, absolutely no sign of him on Sunday, I've been waiting 3 hours, no phone call, not answering his phone.. I'd much rather sell to somebody else.
I've put more new parts on this now. It has new brake hoses throughout, new master cylinder, and another new wheel cylinder. (So almost the whole braking system is new including shoes, brake cables, etc) Replaced all the tyres. Rebuilt the dashboard so that the speedo, fuel temp guages all work now, and all the warning lights.
Last Edit: Feb 15, 2015 15:55:53 GMT by datman
Needs to go so its on ebay with no reserve.
Good luck if you decide to throw on a bid.
Last Edit: Feb 15, 2015 15:49:50 GMT by datman
Feb 15, 2015 15:50:03 GMT
SOLD to a man in Hertfordshire.
Last Edit: Feb 22, 2015 12:00:31 GMT by datman
