Hi, I have a 6 dial dash from, I believe, an early Nova SR in my Vauxhall powered Triumph Toledo. unfortunately the PCB on the back is much the worse for wear resulting in all sorts of strange faults like the engine continuing to run when the ignition is switched off!
So I need another cluster, either from a similar Nova, or I believe early Mk2 Cavalier SRis had one exactly the same but for a couple or 3 extra holes for mounting screws. Its not Digital like the Astra GTE, just has 6 analog clocks, 2 large ones for revs and speed and 4 smaller ones for fuel, temp, volts and oil pressure.
Not the best pic but the only one I have,
Thanks, Steve
Thanks, Steve
