Hi, fuel pump wanted per the title. I've a newish one on the car that has failed and the moulded plastic innards can't be repaired. Looking for a a new old stock pump or good used. PM or text to 07880864136.
Would also be interested in a standard Weber carb for the same to replace the worn Ford unit.
Many thanks.
91 Citroen BX Diesel Estate (on the road) 85 Merc 200T Estate 83 Peugeot 205 (on the road) 61 Mini Convertible (on the road) 91 Ford Transit (on the road) 77 Mk1 Transit 60 Rover P4 100 (on the road) Various Moggies/Minis. Plus several others...
Have a carb from a 1.4 cvh in perfect working order. It's a weber but not sure if its any good to you?
Have a carb from a 1.4 cvh in perfect working order. It's a weber but not sure if its any good to you? Thanks for the post - I don't think it will fit unfortunately. Really just want a straight swap to keep the car standard.
Cheers - i'll take a look.
Very helpful - thank you. My 205 has a solex on it and that's not great either so at least I know what i'm looking for.
Glad it helps I've changed the standard carbs on most of my fords for webers & the improvement has always been very noticeable.
