Berlingo van, 1999, white
MOT until mid april, 2014 tax until end of october.
van runs and starts great, had new set of plugs by previous owner (good friend of mine), best starting diesel ive ever had.
its ready to jump in and use.
has a bosch fuel pump too, so bio/veg oil friendly, so even cheaper to run.
rear axle is fine (common on these)
starts, drives, stops.
1/4 a tank of fuel and has a cd player in it.
bad
its done 222k don't let it put you off it runs spot on.
interior is very dirty, and drivers seats has sagged badly in the middle, currently has a cushion on it, drivers seat belt has started to fray also.
one key for all locks. however the rear doors do not lock, a simple padlock would sort it.(they close and handle works, but key does not lock it)
few clunks when driving and exhaust rattle when changing gear, but still does drive well.
has some rust in the engine bay/inner wing area
the only issues its had with me and the last owner is the exhaust snapping, which has now been fixed, and if u pressed the clutch pedal down really hard it stayed down, which was due to its stop wearing away (behind the pedal) and over extending the spring, I ziptie'd a piece of rubber behind the pedal as a temp fix which ive left as it works perfectly.
cheap tax and tested van thats ready to work. £350
ill ad a pic in the morning.
bad
