Sept 11, 2013 18:13:11 GMT
V reg Merc Vito. CDI Turbo Diesel. Van has sliding side doors on both sides and is ply lined and has a carpeted floor. MOT sept 20th. Roof bars. Electric windows. One of the injectors has come loose and come out of the head. Inlet manifold and a few other parts currently unbolted. Therefore Does not run. Quite a straight clean van. No dents but has usual Mercedes rust around wheel arches. Tyres (Hankook 195 70 R15C) are good and one is nearly new. No battery. Comes with handbooks, both keys and V5.
Last Edit: Sept 21, 2013 21:33:58 GMT by datman
Sept 11, 2013 20:03:45 GMT
Would you be able to deliver at all? (I'm in Chichester, West Sussex)
Last Edit: Sept 11, 2013 20:05:06 GMT by shorty87
Sept 11, 2013 22:17:26 GMT
Possibly but its a heavy beast and I would take it very slow that distance and therefore not very economical for me to do it, likely to be cheaper from someone with a bigger transporter lorry or something. I guess you could tow it on a bar but no power steering. I guess it may even be possible to repair the engine here? Common fault apparently but I've never done one.
Sept 11, 2013 23:04:21 GMT
They weight about 2.3 tonne...
Sept 12, 2013 0:14:07 GMT
Thats insane! I would have expected maybe 1.8.
I don't like scrapping things that can be fixed, the drivers seat is perfect, van seats are usually knackered!
This thing has remote central locking and also a mesh bulkhead.
Sept 12, 2013 9:05:18 GMT
Wow that is heavier than I was expecting! Is it possible to get your postcode to get a quote on someone picking it up? Or fixing on the drive could be good, if it breaks down again on the way home I could use the good old AA!
Sept 12, 2013 9:12:51 GMT
2.3 tonnes with 1/2 of stuff inside maybe,they weigh 1800kg approx not 2.3,I doubt even a lwb sprinter weighs that
Sept 12, 2013 10:51:11 GMT
kerb weight is 1675 kg
Sept 13, 2013 20:56:14 GMT
Nice one thanks. PM sent re postcode
Sept 13, 2013 21:34:21 GMT
Are they just stickers or painted sign writing?
Sept 14, 2013 13:52:36 GMT
Stickers and not been on long. peel off really easily. ive taken some off
Sept 17, 2013 1:29:02 GMT
prolly going to pick a few parts off and weigh in, not sure what bits are best to keep tho. tyres but any other favorite parts for these vans?
Sept 19, 2013 23:17:51 GMT
ecu ,immobilizer box and key brings decent money coz vitos always seem to get a start error on the dash which you cant fix Or could stick the injector back in and use a 7mm splitrim bolt to hold the injector in instead of the 6mm one thats probably stripped
Last Edit: Sept 19, 2013 23:20:13 GMT by dubmeister
Sept 21, 2013 21:33:24 GMT
Hmm. sold it today to local garage who are going to see if they can fix it
Sept 22, 2013 10:35:05 GMT
Did you get the full 275?
