Vauxhall cavalier GSI 2000
MOT EXP April 2014
Tax End of this month
Mileage 103,000
Area West london, near Heathrow
Price £3,000
Ricky 07957408953
I have decided with great regret to sell my GSI. This is because she is my daily driver and needs to be put away for the winter weather and I do not have the space. I also feel she shouldnt be used as a daily but tucked away and comes out for weekends not school runs etc. I purchased this car about a year and a half ago and has been my daily driver. I purchased the car as when I was younger I use to drive one and wanted that feeling again but when your alot older you just don't get that feeling lol. Car was restored a few years ago to a very high standard. Interior is beautiful. No silly modifications other than magnex exhaust and slightly lowered on upgraded springs and looks much better. ABS light is on and I will supply to sensors, the rear passenger side door window does not work neither the lock but I will supply the parts.I have had the sump replaced as there was a crack in it and upgarded the gasket. Small oil leak from the oil pressure sensor I think it just needs tightning but I just havent had the chance to take the car to my mechanic. I had the guages fitted for volt and oil pressure but when they changed the oil filter they pulled the wire of the oil sensor so that will need to be put back on. As these cars were easy to steel I had a clifford alarm fitted. I also had all the speakers upgraded to component speakers. I will leave them in but the cd player will be removed. I also had a brand new electric ariel and vauxhall mudflaps.She has also been undersealed when restored. Also there is a problem with the door solinoid as when you lock the car with the clifford pad they come back up so you have to lock it from the key. This happened when we had the hot weather.I personally believe that this is car is in a beautiful condition and hard to find this way. I have posted alot of photos on all areas of the car and will put some up of the engine this evening.
MOT EXP April 2014
Mileage 103,000
Price £3,000
Ricky 07957408953
