86mike
Aug 25, 2013 10:14:25 GMT
Guys, I'm trying to find a set of tyres 215/50/15 but I just can't seem to find any at a decent price. Does anyone know where I might be able to get them without breaking the bank. It used to be easy to buy them but it seems only two companies make them now :-(
ems1
Club RR Member Number: 5
Aug 25, 2013 18:13:04 GMT
If you can go to 225/50/15 there's more choice
1985 Manta GT/E 16v 2001 VW T4 Caravelle
Copey
Aug 25, 2013 19:28:50 GMT
what width are the wheels? would swapping to 205/55 be an option?
Aug 25, 2013 19:36:28 GMT
205/50/15 is standard wear on the back of an MGF so should be cheap and plentiful. Just a thought!
Steve
86mike
Aug 25, 2013 21:38:46 GMT
Thanks guys, would a 205 be OK on an 8" rim? That would make thing alot easier :-)
Copey
Aug 25, 2013 21:45:48 GMT
yeah 205s are ok on an 8, I run em on a 9, though its a bit of a stretch, 205mm is 8 inch, though the rim width is bead to bead, so you may get the slightest bit of stretch, but not noticable really edit 205/50/15 on 15x8s . EDIT: Just for VIP
Last Edit: Aug 27, 2013 9:21:36 GMT by Copey
86mike
Aug 25, 2013 22:01:41 GMT
Fantastic! I've heard mixed reports whether it's ok or not. I found this pic of a quattro and thought the 205 tyres looked fine. Your Falkens look much better though :-)
Last Edit: Aug 25, 2013 22:02:39 GMT by 86mike
VIP
though the rim "j" is bead to bead, I tried. I really, REALLY tried! But I can't let it go... NONONONONONONONONONONONONONONONONONONONO! 'J' is not a measure of width!
Copey
It's ok to say I am wrong but at least correct me so I know in future...
VIP
It's ok to say I am wrong but at least correct me so I know in future... The letter (or letters) after the number on a wheel specification designate the tyre bead profile (or shape) of the rim that the tyre sits against. However it has erroneously grown to be referred to as a designation of width, a replacement of " if you will. A 7Jx15 wheel is a 7" wide 15" diameter wheel with a J tyre bead profile. From Car Bibles
Last Edit: Aug 27, 2013 9:54:05 GMT by VIP
Copey
Aug 27, 2013 10:05:44 GMT
Learn summert new every day, cheers
86mike
Aug 27, 2013 16:50:04 GMT
I think I've found the tyres I'm going to get. 215/45r15 instead of 50r15 They look like this on a quattro, what do you guys think?
Copey
Aug 27, 2013 19:25:16 GMT
ahh sweet, if they are more readily available go for it
